t25 feed line banjo
Old Jun 14, 2006 | 10:05 AM
Sicktght311's Avatar
t25 feed line banjo
Anyone know what the fitting size is for the turbo feed line banjo? On the TSI t25 turbo it uses those stupid metal hard banjo fittings. The outlet of the fitting obviously is 1/8"NPT to connect to the oil line but the actual fitting on the turbo itself looks a little bigger, and considering the bolts used were standard and not metric i'm sure its gonna be a pain in the a$$ to find a replacement for it without having to buy a whole new feed line.
https://www.evolutionm.net/forums/at...chmentid=58270
check out that pic, its the fitting facing you with the bend in the line. I'd take a replacement banjo if need be but a direct 90 elbow fitting would be more ideal for a direct flow
Old Jun 14, 2006 | 10:13 AM
may have just answered my own question......7/16 inverted flare to -3an (1/8NPT)?
Can anyone confirm?
