High comp pistons and boost?
Old Mar 8, 2007 | 06:44 PM
  #31
Mirage2.0's Avatar
Thanks. Are there any other injectors I could use?
Old Mar 8, 2007 | 06:52 PM
  #32
ambystom01's Avatar
I'm sure there are others but I can't think of them. You might not even need them, you're not running obscene amounts of boost and assuming you do the smart thing and lower that compression you won't exactly be taxing the system you have.
Old Mar 8, 2007 | 06:55 PM
  #33
Mirage2.0's Avatar
Thanks bro. One more question. Do you know by any chance how think are the rpw head gaskets? (mm)
Old Mar 8, 2007 | 06:59 PM
  #34
kungfugirl's Avatar
Originally Posted by Mirage2.0
1) Can I use WRX injectors? Which year?
2) Are there any other head gaskets available besides rpw?
perhaps search, any forum you go too, your gonna need to search to find the info before you are redundant.
good luck
Old Mar 8, 2007 | 07:02 PM
  #35
Mirage2.0's Avatar
good luck
I do search, newbie. That's why I already know I can use wrx injectors but don't know which year. So please do yourself a favor.
Old Mar 8, 2007 | 07:03 PM
  #36
ambystom01's Avatar
http://www.rpw.com.au/shop/index.php...mart&Itemid=31
Old Mar 8, 2007 | 07:09 PM
  #37
Mirage2.0's Avatar
thanks.
Old Mar 8, 2007 | 07:43 PM
  #38
kungfugirl's Avatar
not trying to be in a conflict here.
glad u can read my status on the left. I have been working on this platform for a bit longer than u i can assure you, so please "do yourself a favor" and search before u come into amby's thread and ask about size injectors.
dont carry this on lets be on topic.
amby how many pounds of boost will u be running? 5 or 7? what fuel managment will u be using as i see u live in canada, the weather can't be to friendly there ay?
thanks
-cindy.
Old Mar 8, 2007 | 07:49 PM
  #39
kungfugirl's Avatar
Originally Posted by ambystom01
Only RPW makes decompression gaskets. For injectors you can use the pink WRX injectors but I don't know what year those are or anything other than they are pink.
i thought the injectors we could use were like a teal? or bluish green? correct me if im wrong..
-cindy
Old Mar 8, 2007 | 08:05 PM
  #40
DRFTKNGG's Avatar
You need reliable power. The chance of detonating with the high compression ratio is evident.
Race fuel is a must. Methanol injection bare minumum for it to stay together for 6 months....if a head gasket doesnt let go first.
Old Mar 8, 2007 | 08:12 PM
  #41
Mirage2.0's Avatar
-cindy
STI has pink ones. WRX has blue. Now the question is: From which year?
Old Mar 8, 2007 | 08:21 PM
  #42
Mirage2.0's Avatar
I'll either go with 1.5mm or 2.2mm head gasket.
Old Mar 8, 2007 | 08:56 PM
  #43
ambystom01's Avatar
Do a search mirage2.0, you can find that info very easily. I thought the applicable injectors were pink but I'm not sure since I don't really have any reason to care that much.
DRFTKNGG, we're talking about a lancer here, not an evo. Premium is obviously needed as with any turboed lancer but I don't think race fuel is needed unless you want to run a lot of boost, same goes with methanol injection.
kungfugirl, at the moment the wastegate (Tial) I have at the moment is set to 5.8 PSI so I'll be starting at that. For fuel management I already have a bored fuel rail but I also have a 12:1 FMU ready to go on and a RRM piggyback for tuning.
Old Mar 8, 2007 | 09:43 PM
  #44
petey pab's Avatar
the wrx injectors are blue from 02-04 and maybe newer as well. they are 440 cc. celica gt-s 2ZZGE injectors work as well. they are 310cc i believe? and 88-91 rx-7 and 93+ supra N/A injectors work also.
Old Mar 9, 2007 | 10:21 AM
  #45
Blacksheepdj's Avatar
Pink injectors are just larger flow rate. Blue ones are the stock WRX.
