trying to Add a amp or volt grauge
Old Oct 14, 2006 | 01:13 PM
mrtrunks's Avatar
I've look every where US lancer, RA Lancer, Evo and very other area on this site so I'm giving in an asking how to hook up an amp / volt grauge? I bought a $20 one from Advanced Auto for the time being (lack of money) and I'm running a stock system. The reason I'm doing this is two weeks ago my car die before going to work. If I had an battary grauge on my cluster I would of seen this coming and gotten a new battary. One more thing does any of the lancer have a battary grauge on it already if so could I use the wire for that since the wire harness should be the same. Thanks guys
Old Oct 14, 2006 | 01:15 PM
BoostWhore's Avatar
a volt gauge would jus be tapped into a 12volt source such as the ignition harness
Old Oct 14, 2006 | 01:18 PM
mrtrunks's Avatar
Does that run thought a fuse if so I was told not too because it could give me a bad reading. if not then could you tell me where the ignition harness is?
Old Oct 14, 2006 | 02:18 PM
Bigjoeski05's Avatar
I have a volt gauge and i put a fuse connector on the end of the wire and plug it into a empty slot on my fuse panel. Works Perfect
Old Oct 14, 2006 | 02:33 PM
mrtrunks's Avatar
how long has it been installed?
