Hey guys...Questions from the subie world
Old Mar 11, 2007 | 11:42 AM
drewwrxrogers's Avatar
Hey guys. I am from the subie world and we have a lot of respect for Mitsubishi. My 03 wrx has 315whp with a BIG16g...Thank you Mitsubishi! I am getting ready to install my next setup in a couple months expecting upwards of 350 AWD hp to the wheels......20g, 38mm EWG, 3inch catless Exhaust, 750cc incjectors, BIG top mount....ect.
Anywaz...... One of my good friends has an OZ lancer and has finally decided to go to the boost side. Right now all he has in an exhaust and an AEM intake. We have done a lot of reading on here and have decided to go with something like the RRM kit. It seems to have everything he needs for a 170-200hp application. NO tranny upgrades? I just cant belive that's all that is needed. In the subie world......if you want anything over 280whp......you must replace your tranny with stronger gears or an STI 6-speed. I chose to get a set of stonger RA gears that cost me a total of 2500.
So if there is anything else that is needed at all that isnt really talked about in the description to get the most out of the kit......let us know. From what I have gathered.....370cc injectors and a pre-programed piggyback with allow for increase in boost. Things like this is what we are looking for. Would also like to know the stock hp of the oz lancer. Thanks guys. And While I am here I might go check out some of your guys EVO members. Thanks
Old Mar 11, 2007 | 12:30 PM
クリス's Avatar
I'm not entirely too sure about tranny upgrades, since damn near anywhere over 300 is uncharted territory for the lancer. In order to run higher boost, however, you're gonna need to set up your friend with forged internals. You don't wanna be runnin 9-12 psi and throw a rod now do you? Good luck!!
Old Mar 11, 2007 | 01:34 PM
Blacksheepdj's Avatar
Stock tranny is quite beefy enough. It's pretty rare for one to go, and when they do it's usually old age.
Stock CHP - 120 (so it's roughly 100 whp)
If you want to up the boost, you might want to look into internals. Pistons and rods are a wise choice. On the stock block, you can run high single-digits. Pistons and rods are both pretty weak, though. RRM sells aftermarket solutions for both, though.
Look into an LSD, though. That's a big weakness on the boosted Lancers - all the power tends to get thrown away on wheelspin. Again, RRM sells an LSD unit.
Otherwise, it's all very turn-key. The RRM kit is pretty much a perfect setup for the Lancers. And RRM will work with you to build a monster setup if you desire.
Old Mar 13, 2007 | 12:49 PM
iyi0521's Avatar
When stock i put down 92hp on the dyno.
Old Mar 13, 2007 | 01:28 PM
drucea's Avatar
Also, if you are planning to go with an RRM kit, sell your buddy that 16G and ask RRM what they can do for you if you already have the turbo. You might be able to save a few bucks.
Old Mar 13, 2007 | 04:18 PM
Thanks for the info so far guys. So you think the guys at RRM can actually fab. a kit for my BIG16g. I am sure you already know that the big 16g is diffrent than just a 16g. 50cfm to be exact. Not to mention it pulls like an 18g with the spool of a 16g. LIke I said above. I didnt push my car to much to get that 315whp. It would be pretty fun to see what it would do for his lancer, even at only 7psi.
As far as traction problems go.......they are as unheard of in the subie world as tranny problems are unheard of here. But that should be expected on an AWD. Some guys do install LSD diffs when they do the six speed swap on the WRX...but its not really to important if you ask me. I could see its importance with the lancer though for sure.
Internals are the next upgrade of importance I take it? Makes sense when your uping your HP by close to 100. Pistons and rods I am assuming. Now this is only needed if your wanting to exced the boost of 7psi right.
Let me know whats up guys.
Old Mar 14, 2007 | 10:23 AM
Yes, you want to do pistons and rods. They're a definite weak point on the Lancer.
The Lancer platform definitely needs an LSD to put down the power. Even stock, it would make a huge difference. Trust me on that.
Yeah, RRM can put together a kit for you. I'm sure you'll get a good deal since you already have the snail and you're just getting the rest of the parts.
Old Mar 14, 2007 | 10:27 AM
drucea's Avatar
RRM can do it, they use a regular 16G on their normal kits I think and are using a 20G on their drag lancer.
Old Mar 14, 2007 | 01:57 PM
クリス's Avatar
I've heard that the lancer can take up to around 9-10psi, but that's PUSHING IT. I'd go for forged internals if you're going to boost. period.
Old Mar 14, 2007 | 01:58 PM
drucea's Avatar
It also depends on the turbo, but yeah, I think 9 lbs would be the highest I would go and even then I wouldn't drive it too hard.
Old Apr 3, 2007 | 01:22 PM
I am trying to get ahold of RRM. We are going to do my BIG16G setup on his car. They just need to do some custom work for him. I will keep you guys updated on what is going on and show you some pics and numbers along the way. Thanks guys. Any info will be most appreciated.
Old Apr 3, 2007 | 01:57 PM
drucea's Avatar
What kind of info do you need? A big 16G will be nice. He is going to love that.
Old Apr 3, 2007 | 02:35 PM
ROCK's Avatar
HE will love it. Call us when you ar ready.
ROAD/RACE
subi_killer8
Nov 6, 2020 08:47 PM
shaggadelic
West Region
Mar 28, 2011 01:26 PM
AutoMotoSports
Automotosports - Illinois
77
Dec 13, 2010 01:43 PM
4G63pride
Northwest Region
63
May 28, 2010 10:32 PM
Gruppe-S
15
Apr 24, 2006 05:12 PM
