Priming the turbo
Old Oct 8, 2007 | 11:24 AM
Mirage2.0's Avatar
Priming the turbo
What's up people!!!
I have been told that before I start my engine, I should prime my turbo.
Can someone tell me how to do that?
Old Oct 8, 2007 | 12:27 PM
SLVROZ_03's Avatar
If you can, impact gun on the crank pulley bolt. 30 seconds worth. If not, what I do on the Civic is pull the ECU fuse and "try" to start the car (basically cranking it over, but not starting) for 30 seconds.
Old Oct 8, 2007 | 12:52 PM
Mirage2.0's Avatar
thanks.
Old Oct 8, 2007 | 12:54 PM
drucea's Avatar
Its really easy. We did it last weekend. Just disconnect those plugs from your injector wires (just so that theres no spark going to your plugs). Then hold the oil feed line over a bucket or something and have someone turn the key for about 10 seconds, then wait about 15 seconds, then do it again. Keep doing that till oil comes through the oil feed line. Then bolt it back to the turbo and plug you spark plug wires back up and start the car.
Old Oct 8, 2007 | 01:41 PM
senate6268's Avatar
^^^^^ Follow what drucea said ^^^^^ You just want to make sure you have oil going into the turbo right away so it's not starting up dry.
Old Oct 8, 2007 | 01:43 PM
SLVROZ_03's Avatar
Hope you don't flood with fuel!
Old Oct 8, 2007 | 02:14 PM
senate6268's Avatar
The alternative way would be to get a 1/2" breaker bar or ratchet and just crank away at the crank pulley bolt to get the oil circulating without the use of fuel or ignition. You would also need to remove the fuel pump relay if you follow drucea's steps.
Old Oct 8, 2007 | 02:32 PM
Mirage2.0's Avatar
thanks guys.
Old Oct 8, 2007 | 04:27 PM
SLVROZ_03's Avatar
^^That's why I mentioned the impact gun...not sure if manually turning the crank would pump the oil up and out. Who knows...never had to use that method. I'm sure the Lancer has a ECU fuse that you could pull thus when cranking, it would send any signals to anything and just crank and crank w/o spark or fuel. Works perfectly on Hondas!
Anyone know where the Lancer's ECU fuse is?
Old Oct 8, 2007 | 06:19 PM
kungfugirl's Avatar
could u not just disconnect the coilpacks and crank her?
Old Oct 8, 2007 | 06:22 PM
lancer2show's Avatar
thats what i did. put the oil line in a bucket. run the car for on idle for 10 secs. DO NOT REVV the engine. than make sure oil was coming thru the line.
it would be good to have another person to be safe.
Old Oct 8, 2007 | 06:30 PM
drucea's Avatar
Oh, I wouldn't even start it up, and you guys are making it complicated. No need to mess with the crank pulley. Just unplug the 2 spark plug coil wires (one plug on each of the packs=2), and crank the car for a while until oil comes through. You won't flood the turbo, there's no oil being pumped in until the car starts.
Old Oct 8, 2007 | 06:34 PM
whats wrong with starting up? i mean the turbo is not running on idle....i d/c the coil packs....cranked it for 5 secs than i waited 15-30 secs inbetween times for the next crank. i did this 5 times. oil was still not coming out. i called rrm and they said put the coilpacks back and let it run on idle for 30 secs. within 5 secs oil was coming out of oil line.i dont think you have to d/c the fuel line. because you need air/spark/fuel to run your car and your not getting any spark when the coil packs are d/c
but ya i would not mess w/ the crank pulley thats pretty complicated.
infact you dont even really have to prime the line....but its recommended. its just to make sure oil is coming out because 9/10 oil will be coming out.
Old Oct 8, 2007 | 07:05 PM
kungfugirl's Avatar
Yeh u just crank it.
Old Oct 8, 2007 | 08:59 PM
Brian@RRM's Avatar
if the car is bone dry i personally like the start and let idle for a few seconds. but either way works. some cars take longer to prime.
