BOV Vacuum
Old Oct 21, 2007 | 01:00 PM
Mirage2.0's Avatar
BOV Vacuum
I'm hooking up the bov. I know one vacuum port at IM that I could use but I already have 2 t connectors on it. Basically, where else is a good spot for the vacuum to bov?
Can I use one of the tb port?
Old Oct 21, 2007 | 01:10 PM
lancerrally45's Avatar
why cant you run it off the same line?
Old Oct 21, 2007 | 01:30 PM
Mirage2.0's Avatar
I heard that it's not good since I already have 2 "t" connectors.
Old Oct 21, 2007 | 03:20 PM
SLVROZ_03's Avatar
Get a cheap vac. block; they clean up the tangled mess of vac. line running all over.
Old Oct 21, 2007 | 04:29 PM
Mirage2.0's Avatar
block off the bov vacuum?
I have hooked up everything but the bov is leaking like crazy while idling. I have changed the bov but it's doing the same thing. What could be wrong.
Old Oct 21, 2007 | 04:36 PM
lancer2show's Avatar
i have 05 lancer. we T into the U part of the vacuum line. i have 3 things T'ed into it. my boost gauge, piggy and bov. i can show you a pix if you want.
Old Oct 21, 2007 | 05:21 PM
SLVROZ_03's Avatar
I meant one of these...http://cgi.ebay.com/ebaymotors/Golde...spagenameZWD1V
Old Oct 21, 2007 | 06:29 PM
Mirage2.0's Avatar
Yes please.
What's your vacuum shows at idle? Mine shows -.74
Why my bov leaks?
Old Oct 21, 2007 | 07:00 PM
kungfugirl's Avatar
HAHA, no get a block tht distributes vaccum.
Old Oct 21, 2007 | 07:38 PM
sure ill take a pix tomorrow man. but i remember when i visited RRM you can tap the vacum line kinda behind the intake manifold. it might be more convenient than the U connection.
Old Oct 21, 2007 | 07:48 PM
kungfugirl's Avatar
This is the brake boost cable, yes u can tap this. And also vaccum will be similar even if there ARE multiple taps. Dunno why that the is in caps.
Old Oct 21, 2007 | 07:58 PM
hahaha i just noticed that.
Old Oct 21, 2007 | 07:59 PM
Mirage2.0's Avatar
But I think I need new vacuum spot bc my the vacuum keeps opening the bov.
BOV stays open at idle.
Old Oct 21, 2007 | 08:03 PM
what bov are you running btw?
kungfugirl's Avatar
Pics of your setup?
