internal wastegate question?
Old Apr 24, 2008 | 03:39 PM
cantcatchme96's Avatar
Registered User
Ive never had an internal wastegate, but can you clock the turbo with one? The way each one of these 16g turbos is sitting on the pics, it wont work in my set up at all? So I dont want to buy it yet?
Old Apr 24, 2008 | 03:46 PM
senate6268's Avatar
Stick with an external wastegate. They are better for tuning purposes and function better than an internal wastegate IMO.
Old Apr 24, 2008 | 05:53 PM
Registered User
i have one now, but for only boosting 8-10 i rather do it this way then re route it again, so does neone know can you clock the turbo in different directions than it already comes? w internal wastegate
Old Apr 24, 2008 | 07:47 PM
senate6268's Avatar
Most, if not all, turbos can be clocked.
Old Apr 24, 2008 | 09:02 PM
Registered User
ok it just looks like the internal wastegate is bolted to the cold side of the turbo also and to turn that you would move that actuator bar and wouldnt that screw up the opening and shutting of the wastegate?
Old Apr 24, 2008 | 09:51 PM
senate6268's Avatar
The wastegate and actuator will stay in the current position it is now. It will utilize the new bolt holes that will align when the turbo gets clocked to its new position and the bolts go back in.
Old Apr 24, 2008 | 11:08 PM
Registered User
oh ....k so theres more bolt holes then
Old Apr 25, 2008 | 07:35 AM
senate6268's Avatar
The amount of bolt holes depend on the turbo. I had to clock my new T3 turbo before installing it this week. There were multiple positions to clock it to. Every turbo is different.
Old Apr 30, 2008 | 12:46 AM
Registered User
you got a new t3? what did u have before? how do u like it, because i have t3 now and it spools to damn slow?
Old Apr 30, 2008 | 08:12 AM
senate6268's Avatar
Before I had a 16G6 kit like everyone else. Now I've got a T3 super 60. I wouldn't give my new setup up for the world. The spool is insanely fast. Full boost before 2700rpm. Pulls very, very hard.
Old Apr 30, 2008 | 03:05 PM
Registered User
how much was it, whered u get it?? so its way better than ur 16g, did u have big 16g, srry i know its a million questions
Old Apr 30, 2008 | 03:09 PM
Registered User
does it spool faster than the 16g? ? and i found a turbonetics t3 super 60 for cheap , is that the same one you have, or same performance ??
Old Apr 30, 2008 | 04:24 PM
senate6268's Avatar
The 16G6 is from the Evo VIII. Compared to that turbo, my new one spools pretty much instantly at 9psi and pulls harder than my 16G6 ever did at 11-12psi. It is a Garrett T3 super 60. The Turbonetics should be relatively the same specs. I paid $550 for it new from the fab shop that did my manifold and new piping. Read about it here:
https://www.evolutionm.net/forums/sh...d.php?t=341629
Old Apr 30, 2008 | 07:13 PM
Registered User
thank you!
canyonkid
Mar 9, 2017 10:36 AM
CJEvoIX
Feb 15, 2017 08:17 AM
studioface
Aug 18, 2016 09:14 PM
BaumBizzle
Sep 14, 2011 09:46 PM
burner67
19
Oct 1, 2010 10:29 PM
