White Smoke only on WOT...
Old Jan 22, 2009 | 12:39 AM
  #46
BlackOperative's Avatar
Originally Posted by cincy
Do what you like. You wont be running a large enough turbo to notice either way nor spinning the motor high either. If/when you run a turbo with some lag, you will will understand why compression is worth it when your not a complete slug off boost.
My turbo does have a bit of lag now, but .5 CR won't really make it run sloppy, its just going to be down on power. Lag really won't be affected that much. Think about it, when you raise the head off the block, your intake to exhuast ratio stays the same, because the CR being lowered is a fixed value. In otherwords, it doesnt have an aeffect on air/fuel ratio. The thing to worry about is lowering the CR a large amount, producing such a lower temperature that it will really have a dramatic effect on the turbo spool, because the heat is what turns the turbine, not the speed of the exhuast gasses rushing by the wheel. Did you know the turbo isn't used on most vehicles as a power adder? More power is only a side benifit, its not the actual purpose of a turbocharger. I'll be sure to let you know when i get the parts though, sucks they are coming from austrailia, long time to wait.
awdordie
28
Feb 20, 2016 01:09 PM
UGTSMKD
Nov 14, 2013 11:16 AM
mostafa911
26
Nov 18, 2011 10:08 AM
Jschlo4
Apr 12, 2011 10:13 AM
carlosdevil10
10
Jan 22, 2009 12:28 AM
