RMR Turbo
Old Sep 13, 2003 | 05:41 PM
Biggwill91183's Avatar
RMR Turbo
i currentally bought a turbo from rmr products, they gave me a good deal on it and it does firt in my us lancer with some nugging and pushing, i have it all hooked up but there are actually 3 things that have me baffeld my HKS Super AFR controller is hooked up but there is a wire thats not its one blue wire... another thing is i need to put a plug into my oil pump because on the top of the turbo is where it connects to, the oil drain age hose under the turbo needs togo to my oil pan, and i need to put a bung in it, any suggestions of how todo this especially where the oil pump is located.
Old Sep 13, 2003 | 06:12 PM
yellow_lancer's Avatar
uhhhh isnt this supposed to be in a us lancer part and not evo engine???
Old Sep 13, 2003 | 08:43 PM
leif's Avatar
seriously..wuts with the string of lancer posts in the evo forums.
Old Sep 13, 2003 | 08:49 PM
uranium9v's Avatar
I think you are the only one to own a RMR turbo I've heard of....let's see some pics!!!
Old Sep 13, 2003 | 09:19 PM
fkrzo's Avatar
RMR? sure its not RRM
Old Sep 13, 2003 | 10:40 PM
Nope its RMR out in Huntington beach ill have to get u guys some pics, it was on a concept car/showroom floor car, i got a hell of a deal on it... ill take some pics when im done
Old Sep 13, 2003 | 11:08 PM
Link286XT's Avatar
you need to tap off your oil pressure sending switch, then you need to get a custom oil pan made. rmr didnt include on with your car?
Old Sep 13, 2003 | 11:20 PM
Bitnode's Avatar
i didnt know RMR had a turbo kit.. interesting
Old Sep 13, 2003 | 11:32 PM
ghostrider's Avatar
Very interesting! I thought they weren't making it a public thing since it voids your warranty. Specs! Turbo manifold? T28?
Old Sep 13, 2003 | 11:43 PM
Link286XT's Avatar
or they could be parting out there lancer project car due to lack of interest.
Old Sep 13, 2003 | 11:58 PM
ghostrider's Avatar
True, true. Wonder why they never bothered putting it on the website if they were lacking interest.
Old Sep 14, 2003 | 12:38 AM
Link286XT's Avatar
same way the modern image lancer was parted out to the first highest bidder, eh
Old Sep 14, 2003 | 12:50 AM
liquidlancer's Avatar
same thing witht he street concepts lancer
Old Sep 14, 2003 | 06:58 AM
Naw Mits wanted them to build a Turbo for there us lancer car so RMR and RRM were calling each other back and forth to see what they have done, ex. "o u did that, well we will try this. O we did this u might want to try this also, or that" Just of an example of the 2 companys talking back and forth. Anyways Mits wanted there car back after they seen it work, and they took eveything out and i picked up the everything after that after that.
Old Sep 14, 2003 | 04:17 PM
airlinevomitbag's Avatar
Check this out, I tapped mine here. You have to pull the pan off and there is a metal plate about 3/4" up from that. In that metal plate there is a hole you can put your finger through. Drill the case right about whereyour finger was I made mine like 1/2" and worked a 5/8" tap into it and them covered a 5/8" brass pipe fitting with RTV and screwed it in, be nice the case is aluminum and the threads will pull out if you crank on it. I say to drill above that hole so you can get your finger in there to get all the shavings out.
