Tons of Questions
Tons of Questions
I'm am beginning to build my own kit to turbo my 2005 lancer es.
i've been doing tons of research on everything but still have a few questions
mainly im only going to be boosting 8psi ( 10 max). eventually i will begin to upgrade more and more and increase boost but for now im just going for something simple. why not just buy an evo? mainly because i wanna do it myself and learn.
im going to be using a 16g used turbo out of an evo 8 and the manifold off speedcrops.
1.boosting only 8 psi will the stock injectors be ok?
2. what about the fuel pump?
3. and will i need a new fpr to go with it?
4. where is a good place to buy intercooler piping kits?
5.and i am having trouble finding oil feed / return lines.
all answers greatly appreciated
1.. no
2.. at 8psi it will not push enough fuel for the larger fuel requirments.. so no
3.. i dont have an fpr and the car is running 'ok' with stock, but it does need to be upgraded asap
4.. i have a CX racing intercooling piping kit off ebay(for an evo).. had the pipes all beaded and they worked just fine
4.. your oil feed and return lines varry on the turbo that u use.. but ebay is a normally a good place to start looking.. and turboaddictiveparts.com also has alot of stuff..
