Evo 8 Downpipe and 2002 Lancer Downpipe
hey can anyone tell me off the top of their heads what the differences are in length i think someone told me maybe 2" not sure...only reason i ask is because im thinking about using this item...just seeing what kind of fabrication im going to have to get done to get this to fit
http://www.maperformance.com/map-sta...2e-ss-evo.html
are you turbo? you would have to take about a 12" piece of pipe for it bolt back up to the stock exhaust. to make it work as well you would have to have a custom manifold to accommodate the evo dp.
there are quite a few differences between ours and an evo's
josh
josh
thanks for the reply but i guess i should have been more specific...no not turboed...yet...i do understand if im not using a 16g turbo im pretty sure im going to have to change the flanges to accommodate for the type of turbo im using...just was curious with the major differences with length wise...seen lots of people on here doing their custom setup and alot are using the evo 8 dp...but would like to go with aftermarket...thanks again though
