Turbo Help
Old Feb 24, 2011 | 11:58 PM
2009-4B11's Avatar
Turbo Help
Hi there, I was just wondering if aftermarket turbo manifolds and turbos made for the ralliart/evo would be compatible with the N/A 4B11? I already know that the stock ralliart/evo ones are compatible, but I want a better manifold and turbo than is what's on it stock. Also, are any internals from the 4B11T compatible with the N/A model? Stock or aftermarket. Thanks
Old Feb 25, 2011 | 12:28 AM
Panis's Avatar
Dude, search before you ask.
Old Mar 4, 2011 | 12:25 PM
dadsgts's Avatar
Do yourself a favor. before you jump into turboing your car read up on how a turbo works. To answer your question, The evox turbo and manifold will out perform your motor at all levels. people hit 450hp on sotck manifolds and turbos all day longs. If you think your going to achieve that your strongly mistaken. You can buy a fp red or green and run your 8 psi and still only going to makw 210hp regardless of turbo and manifold combo's. Dont waste your money on bigger turbos and tublar manifolds you will never see the benfit of either one running such low boost.
rong.
Mar 15, 2017 08:09 AM
bumble.beast
Apr 10, 2016 07:17 PM
matizzay
Canadian
17
Mar 28, 2012 12:29 PM
Nocturnal Ryda
Lancer Engine Management / Tuning Forums
16
Apr 14, 2009 05:31 PM
GTS08
Aug 30, 2008 06:52 PM
