Intercooler question!!!
Old Feb 22, 2004 | 03:03 PM
Drive02Lancer's Avatar
If i go intercooled....could I run more PSI safely??
like instead of 5-6 psi on stock internals could i run like 7-8 psi because of the intercooler??
Old Feb 22, 2004 | 03:50 PM
JVlancer's Avatar
sure can.. but keep in mine take a look at the pictures that link took and look close on how small the rods in our cars are, about the width of a pencil, i run only about 6-7 psi right now because my fpr sux junk and i need a c-note to get another one, but you can run it no sweat just need that boost controller or u boost spike and pooof
Old Feb 22, 2004 | 03:55 PM
TURBOit's Avatar
yea, running at 5 psi you will spike to 7 for a short period of time, if your boosting 7 you may spike to 9 (i dont know), but i DO KNOW for a fact that the lancer can be boosted at 9 psi, but i see your an auto, and so am i, so taking boost to 9 is a scary thought, nobody wants a blown tranny
Old Feb 23, 2004 | 02:38 AM
IILANCERII02's Avatar
Try contacting RRM . . . im sure with whatever quesitons you have about the tubro and IC - you can ask them and im sure they will have an answer.
** assuming you have their turbo and IC? **
Old Feb 23, 2004 | 04:37 AM
Boni's Avatar
you can boost 9. will you make more power with your stock ecu? answer is no you dont have enough fuel. at least with the rrm kit you dont. thats why you can only turn it up to like 6-7. but with their stage 2 it adds more fuel with the piggy back computer therefore you can run like 8-9 boost and MAKE power. i dont know what kind of setup you got drive02 so it may be different (if you got some sort of ecu mod. that is).
Old Feb 23, 2004 | 06:30 AM
HobieKopek's Avatar
He hasn't done his mods yet.
Though it's obviously gonna depend upon your fuel setup, something running stock injectors and raised fuel pressure will run into the exact problem Boni pointed out. You can only flow so much on the stock ECU and (more importantly) stock injectors. With fuel tuning you shouldn't need an intercooler to run 9psi, but you would certainly be wise to add one. It's really going to be dependent upon turbine size too, because a smaller turbo like the T25 will be blowing hotter than a larger turbo like the T3/T4. (These seem to be the smallest and biggest turbos respectively that are commonly used). I think one thing you're going to find is, when it comes to raising the boost, heat and fuel are going yo be your main obstacles.
Old Feb 23, 2004 | 11:02 PM
ok thanks...
im not sure im gonna use a t25 or an old 87-89 Starion turbo(don't know what turbo they use exactly) but im 80% positive gonna use the Starion Turbo/Intercooler setup.
Fuel wise im gonna use stock injectors , walbro 255 fuel pump, and a rising rate FPR and than an s-afc also.(disconnecting the o2 sensor so i can tune with the s-afc as some have figured out is possible)
is that enough for 7psi daily(with boost controller to stop the spiking?)
thanks guys.
Old Mar 16, 2004 | 02:28 PM
mobius97's Avatar
The starion intercooler is crap man......if you want a cheap intercooler go with a 1/2g elipse sidemount..they flow much better and cool better too. A few guys have modded the starion intercoolers on eclipse's to have that "front mount intercooler look" just to realize their stocker yeilded much better results. Just an FYI for you. I also posted in another thread. Choosing the starion turbo over the t25 may not be a good Idea...the t25 is water and oil cooled...
Old Mar 16, 2004 | 10:05 PM
KillahB's Avatar
Or get an NPR one. I have a nice small FMIC for sale too... it was too small for my turbo needs.
Old Mar 16, 2004 | 10:32 PM
mobius97's Avatar
Had to correct myself here as I did in the other post "a Few quick ?'s"......starion/conquest turbos ARE oil/water cooled AFTER 1985.
Old Mar 17, 2004 | 04:45 PM
thanks man, yeah im gonna go with the t25 from an eclipse and i gues the eclipse sidemount intercooler. not sure. i want the fmic look though..and $700 for rrm's ic is way to much...maybe i wont go IC and keep 5psi non IC til i can get a nice one. who knows
thanks for the info though!
Old Mar 17, 2004 | 04:48 PM
pgmike's Avatar
what are the dimensions of the largest IC we can use?
Old Mar 17, 2004 | 04:56 PM
according to RRM its 18x7x3 bigger than that u have to cut the body/frame to fit any bigger...
Old Mar 17, 2004 | 04:59 PM
Hotshot940's Avatar
check dimensions of the road race intercooler on their website...its the largest we can use without altering the front of our car at all
Old Mar 17, 2004 | 05:42 PM
pgmike's Avatar
thats what they say but im not sure about that.
