Turbo Help!!!!
Old Sep 9, 2004 | 04:49 PM
NITROHEAD's Avatar
Turbo Help!!!!
I Have the RRM intercooled turbo kit. My car has been running like **** since its been on. No one has figured out why. So it told stoped running last night and had to me towed to a shop. Any ways i was wondering what kind of harness i need for my apexi turbo timer. I heard it was a second gen harness of something. Please let me know.
Thanks
Old Sep 9, 2004 | 04:52 PM
TURBOit's Avatar
2nd gen eclipse if im not mistaken
Old Sep 9, 2004 | 09:05 PM
Dookie's Avatar
What kind of vacuum are you holding at idle? If it's not around 18, then you most likely have a vacuum leak somewhere. What stage are you running?
Old Sep 9, 2004 | 09:37 PM
NITROHEAD's Avatar
Where can i get the harness? Also ill find out tommorrow.
Old Sep 9, 2004 | 10:36 PM
Hotshot940's Avatar
didn't you buy the kit used?
Old Sep 9, 2004 | 10:48 PM
4G63 Racer's Avatar
yes it is a 2g turbo timer harness I had one left over from mine 2g and they have the same ignition hook-ups it can be any kind greddy, hks it does not matter
Old Sep 10, 2004 | 07:18 AM
JVlancer's Avatar
Not all the time this can be caused with a vacuum leak, My car was running like *** for a few days couldnt find the problem at all until i looked at my MAS and there were 2 wires cut from it ... hooked them back up and i was back in business... but the only reason i found that out was because of an obdII code checker
Old Sep 10, 2004 | 07:20 AM
JVlancer's Avatar
and i was reading -10-8 hg but it was no vacuum leak.
Old Sep 10, 2004 | 12:38 PM
.L.'s Avatar
.L.
i know you said your car is running like **** but..... what exactly is it doing? it would probably helped if you described the problem.
Old Sep 10, 2004 | 12:53 PM
Boeturbolancer's Avatar
sure would... then someone could help you out... hint hint!!
Old Sep 10, 2004 | 01:55 PM
.L.'s Avatar
.L.
well there you go nitro..... boe is ready to help. so explain!
Old Sep 11, 2004 | 11:01 AM
NITROHEAD's Avatar
The guy at the local shop said i need a new MAS. Because The guy that did my install he said banged up may MAS. Thats was the mechanic said. So i find out more monday.
Old Sep 11, 2004 | 11:26 AM
Hotshot940's Avatar
oh ****, thats not good at all, i hope that machanic has a few bucks layin around for a new one if thats true...
Old Sep 11, 2004 | 05:06 PM
RRM has a spare... maybe they'd sell it???
