-   Lancer Aftermarket Forced Induction Tech (https://www.evolutionm.net/forums/lancer-aftermarket-forced-induction-tech-57/)
-   -   ITB's, twin tbs, anyones help (https://www.evolutionm.net/forums/lancer-aftermarket-forced-induction-tech/328186-itbs-twin-tbs-anyones-help.html)
CoastieOZ Feb 26, 2008 01:48 PM
Okay considering a twin throttle body system, and need advice from experts.
Is anyone currently successfully running a twin throttlebody or individual throttle body system on a USDM lancer 4g94 or 4g93, successfully on a daily driver?
IF yes what does your setup contain? hp and tq ranges? any info?
hope someone out there can help
MK3Design Feb 26, 2008 04:05 PM
You probably wont gain anything on the twin tb on the 4g94.
I'm sure you would see something on ITB's but I'm not sure the time and effort would be worth it.
As for the HP/Torque ranges, I am 99.998% positive that you would have to find out yourself as I don't think anyone has dyno'd a set up like this on a 4g94 yet.
CoastieOZ Feb 26, 2008 04:50 PM
well i've heard for an n/a guy it can put me above the 150hp mark,
anyone else?
drucea Feb 26, 2008 05:00 PM
The main gain would be if you got the setup tuned with an engine management system. With a full exhaust, and ported intake manifold, and a good tune it could probably put you up there.
CoastieOZ Feb 26, 2008 05:04 PM
drucea, you probably came closer than anyone did? did you ever have it installed and running?
ambystom01 Feb 26, 2008 06:09 PM
Nobody has done it. The twin TB kit from A2 Designs was crap and disappeared. RPW has a kit I believe but it costs a fortune, is a pain in the ass to tune and is a waste of money until you have a heavily modded car. This isn't a bolt-on part, it's a major mod that requires a lot of skill and money to work properly. For the price you could just turbo the car.
CoastieOZ Feb 26, 2008 06:25 PM
ambystom, couldn't you just determine the cfm on a regular intake then figure how much of an increase would be needed in fuel for the second throttlebody and adjust accordingly?
i know some carb's guys (not lancer's) that have some trick two barrels four barrels, twin four barrels, six shooters, etc. that might be able to help me with the tune
but would the 4g94 be able to take that much air and how bad would it deplete engine life.
ambystom01 Feb 26, 2008 06:32 PM
Not really, it's more involved than that because the flow of one can affect the flow of the other. People have a hard enough time tuning for ITBs let alone twin TBs. At the moment it's a waste anyways, the car isn't starving for air and there's way better mods you could do than spend 3000$ on a TB kit.
drucea Feb 26, 2008 07:04 PM
Technically I had the "twin throttle body" part installed, but I left the second TB closed and the car ran like normal. At that time, I didn't have the money to test different pipe fittings to run piping for both sides. So I never found out if it would run at all with both TBs connected to the MAF sensor. But according to everyone else, it wouldn't have worked at all. I still have one for my car though, and maybe one day just for ****s and giggles, if I have too much free time, I'll put it back on and run piping to both sides just to see what would ACTUALLY happen.
CoastieOZ Feb 26, 2008 08:26 PM
thanks guys, you answered my questions and i'm guessing there are no lancers on these boards running more than 1 throttle body.
ambystom01 Feb 26, 2008 08:44 PM
Nope, not much point really.
kungfugirl Feb 26, 2008 10:55 PM
honestly i used to hate people who said this but...
buy a turbo..
CityKnight Feb 27, 2008 02:11 AM
You could twin-turbo with that twin tb kit..
Kurt Feb 27, 2008 05:10 AM
Why? I highly doubt a twin turbo setup would be effective on a four cylinder.
ambystom01 Feb 27, 2008 07:02 AM
What? You can twin turbo with a single TB like pretty much any twin turboed car out there. If you're referring to some of the kits out there for V6s and the like, you're missing the fact that those cars have two or more banks of cylinders, the lancer has one. What happens on the intake side doesn't necessarily correspond with what happens on the exhaust side.
