-   Lancer Aftermarket Forced Induction Tech (https://www.evolutionm.net/forums/lancer-aftermarket-forced-induction-tech-57/)
-   -   Pete's 03 Lancer RRM turbo built (your input is appreciated) (https://www.evolutionm.net/forums/lancer-aftermarket-forced-induction-tech/553599-petes-03-lancer-rrm-turbo-built-your-input-appreciated.html)
Evo Pete MTL May 1, 2011 10:33 AM
Hey guys,
I never thought this would happen but I got a good deal and decided to go turbo. I'm starting the install this week. I want to first use the FMU and then learn how to tune to go with bigger injectors, etc.
Here is what I have so far:
STAGE 1 (5psi, no tune):
                    Stage 2 (7psi, tuned):
                            Still need to buy:
                                http://img.photobucket.com/albums/v7...0/IMG_0362.jpg
                                http://img.photobucket.com/albums/v7...0/IMG_0361.jpg
                                http://img.photobucket.com/albums/v7...0/IMG_0360.jpg
                                http://petevu.com/images/DSCN0199.JPG
                                MurphDurph May 1, 2011 10:56 AM
                                when you hit your "stage 2", you really wont need the fmu...regardless you will need to tune it...its all just a game of chance when the rods will go, so be careful :mitsu:
                                Evo Pete MTL May 1, 2011 11:21 AM
                                Some questions:
                                I forgot to mention my car is A/T. Some questions I have:
                                        Thanks in advance,
                                        Pete
                                        Evo Pete MTL May 1, 2011 11:22 AM
                                        Yeah that was a mistake in my post. Thanks for pointing that out!
                                        MurphDurph May 1, 2011 11:29 AM
                                          evo battery tray will work, but relocating to the trunk is much better
                                            your stock radiator has a built in transmission cooler (only A/T have them)
                                              you dont need a turbo timer cause its water cooled
                                                yes you should upgrade your downpipe. i dont think the evo downpipe will fit the RRM kit without havin your flanges swapped to fit. highflow cat is also a good upgrade or just a testpipe.
                                                Thanks in advance,
                                                Pete
                                                :mitsu::mitsu:
                                                steven121 May 2, 2011 11:00 AM
                                                Yea bro he's right tuning is the key thing to make your actual build successful. I tuned everyday to get my car where its at. Even though I'm taking a big risk but only take risk of you can back it up I have a built motor so no worries there
                                                Evo Pete MTL May 4, 2011 09:00 AM
                                                Yeah I'm still reading on the forums to learn how to tune so for the moment I'll just run the FMU with 5 psi.
                                                How do you guys log? Do you go to the drag? I heard you need a perfectly flat and smooth (no bumps) road in order to get good readings other than on a dyno.
                                                holycrap300 May 7, 2011 01:37 PM
                                                Nice, i think i remember this setup for sell :)
                                                I would love to see this car one day!
                                                Evo Pete MTL May 7, 2011 04:04 PM
                                                You're in Montreal so it's most likely to happen! I'm starting the build tomorrow, I'll keep you guys posted on how it goes.
                                                -Pete
                                                steven121 May 7, 2011 04:54 PM
                                                -Pete
                                                sweet man more and more turbo lancers are joining in. Take pics with your thread we like to look even though we already have turbo lancers :D
                                                Evo Pete MTL May 8, 2011 06:27 PM
                                                DAY 1: Time spent = 4 hours
                                                Ok so we started today and got disrupted a couple of times but we managed to install partially the fuel pump, remove the radiator, manifold and downpipe as well as the intake.
                                                My issue with the fuel pump is that I cannot close back the pump assembly in the tank (I did not try to screw it back, but there was a big gap). I also broke 2 bolts. Should I try to screw it and force it or should I get an extra rubber seal/gasket from the dealer?
                                                Here are some pics of my install:
                                                Car looks new...
                                                http://img.photobucket.com/albums/v7...0/IMG_0363.jpg
                                                Until you get to the fuel pump! No idea yet how to seal it back with the gap:
                                                http://img.photobucket.com/albums/v7...0/IMG_0364.jpg
                                                Fuel pump assembly:
                                                http://img.photobucket.com/albums/v7...0/IMG_0367.jpg
                                                Engine bay, before turbo install (I did an engine shampoo before install):
                                                http://img.photobucket.com/albums/v7...0/IMG_0365.jpg
                                                Intake removed (ok I know, no big deal...)
                                                http://img.photobucket.com/albums/v7...0/IMG_0368.jpg
                                                Engine bay after radiator + exhaust manifold removal:
                                                http://img.photobucket.com/albums/v7...0/IMG_0374.jpg
                                                Front of car (I'm keeping the crash bar and going for a smaller FMIC, safety 1st:
                                                http://img.photobucket.com/albums/v7...0/IMG_0369.jpg
                                                Evo Pete MTL May 8, 2011 06:37 PM
                                                It looks like the stock 02 sensor won't be long enough to plug into the new manifold and I heard in Steven's turbo thread that you CANNOT extend it from anywhere close to the harness it has to be done on the other side of the firewall, near the ECU. Why? they just seem like regular copper wires to me...
                                                Cannot be extended anywhere here?http://img.photobucket.com/albums/v7...0/IMG_0366.jpg
                                                Or there?
                                                http://img.photobucket.com/albums/v7...0/IMG_0370.jpg
                                                Green_Bandit May 8, 2011 09:15 PM
                                                Huh? That o2 sensor should reach. You sure there is no clip holding it in place?
                                                Evo Pete MTL May 9, 2011 06:29 AM
                                                I tried really quick but I recall seeing this in the threads so I guess I took it for granted! I'll try again.
                                                slatermvp May 9, 2011 01:49 PM
                                                you can't extend it from the 02 sensor to the harness but you can extend it from the harness (first picture you have) or you can get a 02 sensor extender. If you look in my thread green bandit posted a link to one.
                                                I'm going to get me one of those extenders but for now I just extended the wires.
