Green_Bandit's 16g build thread
I said two days that thing will be on and me and a buddy did it in 1!
Im going to go into quite a bit more detail by kind of making this a how to and laying out facts but right now I'm dead tired and have some of the minor things to wrap up in the morning like running the O2 sensor, fitting the down pipe and stuff like that. But you better believe that hunk of metal is strapped on and fluids are back in the car! {thumbup} For now just a few images to get going... http://i1210.photobucket.com/albums/...t/IMAG0139.jpg http://i1210.photobucket.com/albums/...t/IMAG0140.jpg http://i1210.photobucket.com/albums/...t/IMAG0144.jpg Later |
Parts list and where to get them...
This is the option I took for extending the O2
Forge Waste gate http://www.maperformance.com/forge-a...-evo-viii.html Where I bought the forge Waste gate for Under $200 WITH the 5-10 pound spring installed. You can also get it with the 10-15 pound spring in it for the same price Wide band and other gauges came from here http://prosportgauges.com/wideband-a...ratio-kit.aspx Evoscan cable and software can be found here http://www.evoscan.com/evoscan-gps-o...flashing-cable Link to ECUflash 1.29a RoadSpikes Big maps link Parent files How to wire AEM to ECU Downpipe springs http://www.streettunedmotorsports.co...olt_spring.htm But I bought mine off of a member on Evom. Also upon further inspection your local exhaust shop should have them oil return fittings and steel return hose. http://www.treadstoneperformance.com...s+%26+Fittings Fair pricing and quick shipping. Just try to order everything at once because minimum shipping charge is $11.00 even if you order a one inch flange Oil feed Well I had one made. 4an line with 4an ends with one end at a 90 degree angle. If you want to know where I went email "Greg @ GO-AUTOWORKS.COM" GREAT customer service and quick shipping. Oil return flange on the turbo just run a search of http://shop.ebay.com/i.html?_from=R4...All-Categories What you need is a 10 an fitting. Should be around $11.00. If they don’t come with the bolts you need to go some place like Tractor Supply Co and get a pack of Hd cap screws. 1.00 x 20 They fit perfect O2 housing If you don’t want a stock one I went with this. http://cgi.ebay.com/ebaymotors/GODSP...ht_3519wt_1009 Good price. It’s a little thin but more open that the stocker. Otherwise look here on Evom Down Pipe Do a search here for a stocker. Should be able to get it around $60-80 shipped depending Doughnut gasket for the down pipe is $20 at Advance Auto Parts |
I thought the O2 sensor extender didn't work for ya??
The one I ordered didnt but they have others. The one they have for mitsubishi defiantly doesnt look like the right one. For anyone looking at those I'd call them first and try to get more information. I couldnt because I received mine with just a few days left till the build
looking good! My build starts on the 10th of next month. Going to be referring to everyones build for mine. I like the powder coated piping. And which o2 housing is that? its not a megan is it? im sure megan is 3 bolt dp flange.
The brand is god speed. Off of ebay. About 30 bucks. Nothing to write home about but better than stock.
I'm getting acquainted with ecuflash but mitsulogger has me off a bit. What exactly am I looking for with it? I'm logging and all but do I chart it with the graph option or watch the play back? What am I missing, there has to be something I'm missing. |
Damn, 1 day, that's quick, ha ha. Some good info, thanks man, can't wait to see more.
Originally Posted by Green_Bandit
(Post 9323550)
(Post 9319543)
this I am not liking though. the upper intercooler piping coming from the im is being pressed down by the strut bar. You do anything to combat that? I have a strut bar but its ebay and not rrm. So Im not sure if I will run into the same issue or not. |
Originally Posted by syntax182
(Post 9324662)
Originally Posted by RoadSpike
(Post 9324677)
I would really look at buying evoscan its much easier to setup and use than mitsulogger. Which isn't a bad tool but its more geared toward someone that knows about the ECU rather than someone that doesn't.
Road spike, I flashed the auto big maps to my ecu but it looks as if one of my starting points is going to be pulling timing about 8 degrees around 80-110 load since I have about 10 counts of knock around 3300 rpm. Sound like a good analysis?
Originally Posted by Jogenmaru
(Post 9325237)
Some more reference pics for you guys
I already had the RRM test pipe so I ended up chopping that up instead of making something new.
started about 12 inches... http://i1210.photobucket.com/albums/...t/IMAG0132.jpg Ended up shortening it to about 5 & 1/2 http://i1210.photobucket.com/albums/...t/IMAG0133.jpg My oil feed. For anyone getting these fittings I had the 45 degree one but while putting it on there the 90 would be easier to work with. Not saying the 45 is jacked up in any way because mine is on there solid and straight but the 90 will give you less hassle http://i1210.photobucket.com/albums/...t/IMAG0136.jpg The oil line cam out to be about an inch shorter than this http://i1210.photobucket.com/albums/...t/IMAG0130.jpg The oil pan, we hondabonded the hell out of it. http://i1210.photobucket.com/albums/...t/IMAG0127.jpg Here is the little notch youre going to have to pry to get the pan off http://i1210.photobucket.com/albums/...t/IMAG0125.jpg You can see it a little better here... http://i1210.photobucket.com/albums/...t/IMAG0126.jpg |
(Post 9326004)
Log your knock voltage and see if on the deceleration your getting big voltage spikes. If so you got stuff rattling enough to make it believe there is real knock. |
and FYI.. that was WAY to much grey silicon on ur oil pan.. If it globs into the oil pan, u could clog the oil pump.. u need a thin line, about half of what u put on there, and u spread it out slightly with a wet finger.(wet finger so it doesnt stick to you as much)
Jesus thats alot of icing on your cake! mmm
| All times are GMT -7. The time now is 05:11 PM. |
