capacitor
Old Feb 26, 2005 | 07:25 PM
byuh20's Avatar
capacitor
Can anyone tell me or post pics on how to install a capacitor
Old Feb 26, 2005 | 07:27 PM
SK Lancer's Avatar
+ from battery -> fuse close to battery -> + on cap -> + on amp
- from chassis -> - on cap -> - on amp
Old Feb 26, 2005 | 09:31 PM
wiretap's Avatar
http://www.caraudiohelp.com/car_audi...stallation.htm
There is detailed instructions and diagrams. First results that came up on google. =D
Old Feb 27, 2005 | 05:22 PM
byuh20's Avatar
So the capacitor has its own ground wire seperate from the amps ground wire and the power wire is connected to the capacitor then goes out the other side of the capacitor straight to the amp. And howmuch is that thing to charge the capacitor.
Old Feb 27, 2005 | 08:22 PM
wiretap's Avatar
Correct.. Most capacitors you buy in the store will come with everything you need, including that little resistor thing. (most are already built in) I was at circuit city the other day looking at them, and I saw one with a built in volt meter on top, in which the resistor was already in it, so all you have to do is just plug it in to your existing audio setup.
Old Feb 28, 2005 | 03:09 PM
byuh20's Avatar
Thanks for the great help
Old Feb 28, 2005 | 03:12 PM
Archangelite's Avatar
hey, this may be off subject, but since were here...
if i turn off the car and my cap is still reading voltage (digital cap) is it hooked up wrong? it reads the voltage but it slowly goes down untill it dies out.
Old Feb 28, 2005 | 05:34 PM
macster's Avatar
Sounds like it's working fine.
m~
Old Feb 28, 2005 | 07:09 PM
wiretap's Avatar
Thats what capacitors do.. they hold a charge. It will take a while for it to die down. That is normal. =]
