need help
Old May 9, 2006 | 09:57 PM
edgard's Avatar
need help
im putting 2 type x alpine subwoofers in my lancer what kind of amp will i need to push these speakers and i was thinking isnt this too much for my car their rms is 1000w!!
Old May 10, 2006 | 06:41 AM
BillAce's Avatar
THe sub RMS is meaningless. Speakers waste tons of power, they don't make any. That usually means the subs are cheaper, and the marketing dept has more to do with them than engineering.
What impedance are they, are they single or dual voice coil?
Old May 10, 2006 | 02:50 PM
edgard's Avatar
sorry its just that im an newbie on audio these are the specs for the speaker
Woofer
• 4-Layer 220ฐC High Temp Wire with Inner/Outer Winding on Twin-Wall Brass Former
• Carbon Fiber/Aluminum Honeycomb Parabolic Cone
• Custom Cast Aluminum Frame
• Designed and Engineered in the USA
• Dual Voice Coil Design
• FEA Optimized CRC T-Drive Motor Structure with Copper Shorting Sleeve & Heat Transfer Technology
• FEA Optimized High Excursion Injected Santpreneฎ Multi-Roll Surround
• FEA Optimized High Excursion Injected Santopreneฎ Surround
• FEA Optimized Mirrored Progressive Nomex Spiders with Integrated Tensil Leads
• FEA Optimized Mirrored Progressive Nomex Spiders with Integrated Tinsel Leads
• Gold Plated Insert Terminal Block with VC Jumpers
• Hidden Screw Gasket
• Integrated Spider Landing and Heat Transfer Plate
• Massive Triple Stacked Strontium Magnets
• Multi-Stage Ventilation System (Dual Flare Pole, Spider Plateau & Frame Leg Venting, Cone/VC Junction Venting
• One-Sided Terminal Layout
SPECIFICATIONS
Power Handling
• Power Handling Capacity (Peak) : 3000W
• Power Handling Capacity (RMS) : 1000W
General
• Diaphragm Material : Carbon Fiber/Aluminum Honeycomb/Kevlar Reinforced Pulp
• Magnetic Weight : 130oz.
• Mounting Depth (top mount) : 218 mm (8.6")
• Mounting Diameter (top mount) : 277 mm (9.1")
• Recommended Box Types : Sealed/Vented/Bandpass
• Recommended Sealed Box Volume : 0.75 - 2.0 cu. ft.
• Spider Material : Nomexฎ
• Voice Coil Diameter : 75 mm (3")
Thiel Small Parameters
• Coil Height (Hvc) : 48.1mm
• Cone Area (Sd) : 529sq. cm
• D.C.Coil Resistance (Re) : 3.6ohm + 3.6ohm
• Electrical Q (Qes) : 0.69
• Equivalent Suspension Stiffness (Vas) : 32 liters(1.1cu.ft.)
• Free Air Resonance (Fs) : 28Hz
• Frequency Response : 23Hz - 200Hz
• Gap Height (Hag) : 10mm
• Impedance (Nominal) : 4ohm + 4ohm
• Linear Excursion (X linear) : 19.1mm
• Maximum Excursion (X peak) : 22mm
• Mechanical Excursion (Peak-to-Peak) : 75mm
• Mechanical Q (Qms) : 8.67
• Sensitivity : 83 dB/W/M
• Total Loudspeaker Q (Qts) : 0.64
Old May 10, 2006 | 04:13 PM
cableguy5752's Avatar
you will need something huge and reliable. Hifonics makes some mono amps at 1000w RMS @4 ohms and they are 1 ohm stable. you can find them on Ebay for pretty cheap ($200-250 range). My neighbor has one and it has proven itself over the last year.
rxtec
Jan 11, 2016 03:47 AM
Vhunter
Feb 19, 2013 10:31 PM
bloodstain008
10
Oct 23, 2008 12:12 PM
ralliart 04 21
04-06 Lancer Ralliart How To Requests / Questions / Tips
Oct 5, 2006 08:45 AM
Rui Evo
Jun 15, 2006 02:17 AM
