crutchfield install pages 02+ lancer
Old Sep 11, 2006 | 07:24 AM
atilla's Avatar
i dug these up for another member and i figured there were plenty of other guys out there who could benefit from it, so here it is, the entire install booklet from crutchfield.
just to make this our one-stop stereo shop, here's the stock wiring harness info from the member "diamondstar03" here oin evom.
"FUNCTION PIN WIRE COLOR
Accessory 12 Volt 11 BU/YW
Constant 12 Volt 10 RD/BK
Chassis Ground BODY
Power Antenna 4 YW
Remote
Illumination 3 GN/WT
Dimmer 9 BK/YW
FUSE VALUE FUSE LABEL FUSEBOX LOCATION
10 AMP #17 DRIVER'S SIDE UNDER HOOD
10 AMP #18 DRIVER'S SIDE UNDER HOOD
If the vehicle is equipped with six-speakers, the tweeters will be wired in parallel with the door woofers. Front speaker wire colors are the same at the tweeter and woofer locations.
Left Front Spkr + 2 RD/WT
Left Front Spkr - 8 RD/BU
Right Front Spkr + 1 RD
Right Front Spkr - 7 GN
Left Rear Spkr + 5 WT/BU
Left Rear Spkr - 13 YW/RD
Right Rear Spkr + 6 L.GN
Right Rear Spkr - 14 YW/GN
At Speaker YW/BK
At Speaker YW/RD
At Speaker L.GN
At Speaker YW/GN"
Old Sep 11, 2006 | 07:28 AM
mds's Avatar
mds
thank you! This is very helpful!
Old Sep 11, 2006 | 07:32 AM
atilla's Avatar
good luck with the install, i have not heard anything about any kind of immobilizer on our cars. if there was one i'm sure i would have tripped it by now somehow. i've done all my own audio work and i have a ton of wires behind my head unit. most of those are because i ran high level input to my second amp and then back when i amplified my speakers.
Old Sep 11, 2006 | 09:52 AM
SLVROZ_03's Avatar
If this diagram hasn't been sticky'd yet, do it mods...
Old Sep 11, 2006 | 10:01 AM
purecoda's Avatar
awesome. very beneficial post.
though i will add (and i'm not being an *** here) the install is one of the simplest things ever - even without the sheets. i wish all the cars i've owned/will own could be as straight forward for replacing the headunit and speakers.
Old Sep 11, 2006 | 10:17 AM
atilla's Avatar
yeah, i never even glanced at these pages during my installs, but i knew that they'd be able to help some guys out. i know when i did speakers on my subaru a few years ago when i was first starting out with all this doing my own work i definitely needed a helping hand.
AhmadHasib
Mar 30, 2007 01:15 PM
essjEVO
Jan 17, 2007 01:35 AM
Invision Evo
Evo 'For Sale' Exterior Styling
23
Jan 5, 2007 11:41 AM
hanahawaiian
Northwest Region
16
Nov 16, 2006 11:57 PM
OldschoolEVO
Oct 23, 2006 02:22 PM
