diagram on how to
diagram on how to
Hi i need a little help i`m used to doing things on my own but i`ve never done an amp install to a factory HU
I was wondering if there is a diagram or how to on to properly install an amp kit to the Factory radio and what i would need ?
So far i have
Amp 700w
Line out converter
Amp wiring kit
2 12" subs
I would apreceate help.
So far i have
Amp 700w
Line out converter
Amp wiring kit
2 12" subs
tap into each channel and run that into the amp--to which you'll use a bridged channel to run your sub. the downside of all this is that you have no independent control of your sub and the bass will change as you change the volume on the stereo.
since you didn't specify the year or model of your car... i can't get you an exact diagram... but i can show you where to go!
http://www.the12volt.com/installbay/...itsubishi.html
