system help needed
Old Feb 6, 2008 | 01:01 PM
thefire's Avatar
system help needed
ok so i dont have pics not but just the other day i hooked up a system to my car and the sub is not beating hard at all..it just barely hits enough that when you put your hand by it you feel vibration. i believe i hooked everything up correctly and i tried switching between postive and negative from the sub to the amp. im running one 10" alpine type r sub with a mrd-m300 amp. im not sure how exactly to set the amp but i was able to get it to a setting i knew it wwoulld work and it had the same output. also the cd player is a jvc. but the rca cables are hooked up, the power is hooked up, the remote is connected to amp and crossed one wire in the dash that i know is the right one and the ground is good. any help?
EDIT: solved problem but posting pics anyways
Old Feb 6, 2008 | 07:14 PM
empire4vr's Avatar
I had a friend with the same problem. He switched out his RCA cables and bingo! Also... if you're not sure how to wire up an amp you should pay a shop $50 and have them do it the right way. Good luck Bro!
Old Feb 6, 2008 | 08:33 PM
thefire's Avatar
yeah i probably should but as for the rca cables they are brand new..i doubt thats the problem
Old Feb 6, 2008 | 09:34 PM
J Money's Avatar
had the exaact same problem..turned out my sub was toast..did u buy the sub new?
check your same set-up with a different sub that you know works..i spent about 2 hours checking and re-checking everything before figuring out it was the sub..
Old Feb 7, 2008 | 06:04 AM
thefire's Avatar
ok well today i have a friend comming over that hooks systems up at best buy so he has a lot more tools to check stuff with and hopefully he can figure out the problem..if not i guess a new sub have to be on the way
Old Feb 7, 2008 | 11:10 AM
empire4vr's Avatar
keep us posted man. Good luck!
Old Feb 7, 2008 | 12:50 PM
SLVROZ_03's Avatar
My guess is the "SUB" control on the HU isn't but at zero...maybe the gain control is at zero too. Good luck!
Old Feb 8, 2008 | 09:59 PM
ace79603's Avatar
you could have the Amp on HFP instead of LFP Ibelive that correct but the crossover on you amp is what I'm talking about. How do you have the amp set up?? Bridged??
Old Feb 10, 2008 | 06:57 AM
thefire's Avatar
ok well i fixed the problem it turned out that it just needed some amp settings fixed which turned out to be really easy after messing with the amp for awhile. i just had to mess with the frequency settings and such and it started beating hard as hell haha thanks for all the help and i added a pic to the first post just to show it off
apparittion
Jul 22, 2015 12:20 PM
2LOFD3ATH
For Sale - Cars For Sale
Jan 17, 2010 07:36 PM
thefire
Feb 12, 2008 12:41 PM
EvoEntropy
Sep 23, 2006 05:05 PM
