Need help on choosing an amp
Old Aug 3, 2003 | 05:10 PM
billslancer's Avatar
Question Need help on choosing an amp
I just bought 2 square Solo Baric 12" subs and I am not sure what amp to buy. They are 2ohm dual voice coils and handle 750 watts each. What type and size amp would you suggest I use.
Old Aug 3, 2003 | 05:48 PM
They hold 750 watts rms and 1500 watts max each.
Old Aug 4, 2003 | 05:56 PM
cupOZnj's Avatar
any amp that can push 750w rms would be fine. wire the dvcs in series and subs in parallel to get 2ohm load, find something that pushes 750wx1 into 4ohms. having 2 4ohm loads in parallel they will each see 750watts. so either look for a 750x1 into 4ohms, or if they label it by 2ohm load, then it would be 1500x1 into 2ohms for the equivalent circuit. if you can afford it, get a class D amplifier.
