Custom Trunk!
Old Jul 22, 2008 | 12:33 AM
Sofla GTS's Avatar
Custom Trunk!
lmao i know what you guys are thinking
oooo look he has another idea that hes not gonna end up doing
lmao well this i plan on doing all i need is some wood and some fabric
and maybe some LED strips
here it goes
well i was planning on fiberglass but frankly i dont have enough time to do this so i will use a regular dual twele inch enclosure and i will place a piece of wood in front of i that cover the entire middle hole in the trunk to act as a wall so to speak.
then the spare tire will be left and the stock cover will be removed.
i will elevate a piece of wood to cover the entire middle area of the trunk and then i will cut a mitsubishi logo into it and fill it in with plexiglass.
then this will be lined with blue LED stripping so it will iluminate blue
the hinges will be installed in order for access to the spare
then on each side where it dips in will be a piece of wood acting as a wall
the left side will me my 4 channel amplifier and it will be sunken in and blue LED strips will again be placed around it
on the right there will be 2 or 3 power capacitors that will illuminate blue
but once i have my mono block amplifier these will be moved to a new location in the trunk.
basically this will be a zero wire install
you will see absolutely no wiring and i mean that
all i need now is to go pick the wood up
and then i am set to start
but heres the "MAP" i drew out for it
lol its 3:22 and i was laying in bed thinking about this and i had to atleast draw a diagram so i did and i wanted to share
but of course install pics will be in order
also im contemplating what color to upholster the wood
i was thnking either white or black
they would both look amazing
heres the pic
Old Jul 22, 2008 | 05:42 AM
MX41's Avatar
I was going to try this, mounting the amp under the logo and illuminating it, but I didn't want to remove the spare tire and I couldn't fab a good box to hold the amp that would fit in the tire, so I said forget it
I hope you really do this because maybe it will compell me to do it when im done fiberglassing and stuff
Old Jul 22, 2008 | 04:12 PM
Sofla GTS's Avatar
dont worry cus this is happening
and im not sure if im going to mount the amp under the logo yet
but i will not remove the spae tire
i will make a hinge to lift the floor and access it
photoshop!!!
Old Jul 22, 2008 | 08:48 PM
yitzac1990's Avatar
my advice: get one big cap instead of 3 smaller ones. it will save money in all that wire and those ring terminals you have to buy, and will look better in my opinion! other than that, cant wait to see final pics!
Old Jul 22, 2008 | 08:52 PM
Sofla GTS's Avatar
well i get those circuit city discounts so whatever lol
Old Jul 22, 2008 | 09:23 PM
yitzac1990's Avatar
dang man youre lucky!! too bad you dont live and work near me haha
Old Jul 22, 2008 | 09:32 PM
yitzac1990's Avatar
oh and another thing, if you get a regular dual 12" box, chances are it will be too deep to still gain access to your spare tire, unless you push the box into the car and take out the back seat haha
Old Jul 22, 2008 | 09:41 PM
Sofla GTS's Avatar
well i plan on raining the sub box form the edges and then i believe i might be able to get the tire out
i will figure it out
im thinking of buying all rockford fosgate stuff to go with the mitsu theme
Old Jul 22, 2008 | 09:51 PM
yitzac1990's Avatar
alright well where there's a will, there's a way haha all RF will be sweet
Old Jul 22, 2008 | 09:53 PM
Sofla GTS's Avatar
yea but i doubt it i will probly get a kicker 1000 watt amp
and some more tsunami caps since they light up blue
i believe the rf caps light up red which is a problem
Old Jul 23, 2008 | 09:03 AM
yitzac1990's Avatar
ohhh ok well if you are electrically handy, you could always CAREFULLY open up the cap and replace the red LEDs with blue ones haha or the rd LCD screen with a blue one, if you could find one.
oh and power acoustics (i think) makes a real nice like 12 farad cap, expensive, but is all blue and is about the size of a small amplifier. I think that would look awesome on the other side of the trunk, sitting opposite the amp.
Old Jul 23, 2008 | 01:01 PM
Sofla GTS's Avatar
Power acoustic isn't my favorite choice brandwise
Old Jul 23, 2008 | 01:03 PM
yitzac1990's Avatar
yeah PA isnt so good, but they make a mean looking cap. btw, this is what i was talking about (sorry, not 12 farad haha!):
http://vortexaudioexpress.com/store/images/PCNC3.0F.jpg
and heres a bunch more:
http://www.ecusad.com/en-us/dept_1063.html
Old Jul 23, 2008 | 03:43 PM
hugador's Avatar
Are you going to install a second battery. It's alway better to have that than a cap. I have a 20 farad installed and second battery. The cap was for my old system but I thouht of adding to my current system since I the bass sounded cleaner more responsive. It could work both ways.
Old Jul 23, 2008 | 06:42 PM
Sofla GTS's Avatar
i was thinking a red top but maybe a blue top optima
and vitzac try this for size
http://www.woofersetc.com/index.cfm?...Product_ID=670
