Quality question
Old Sep 4, 2010 | 08:38 PM
shirk's Avatar
Quality question
Ok, so I have a pretty basic headunit. here http://www.google.com/products/catalog?oe=UTF-8&q=sony+xplod+head+units&hl=en&cid=13165962042519 39641&ei=aQ-DTJ66A6fu2ASvyYDMBg&sa=title&ved=0CCcQ8wIwAjgA&os= tech-specs
and a pretty old amp and 12'' subs i think the amp is a 650watt xplod and stock speakers
when I turn the volume above 35, the sound quality goes down the drain.
I think it's the stock speakers but I'm not sure if it's the amp or the fact that I'm using an AUX cable and not a usb?
any insight will help, thanks
Old Sep 11, 2010 | 10:37 AM
Greedy_son's Avatar
Does the amp power the stock speakers as well? or is it just used for your subs?
If you are using the amp to power the speakers you might to check the gain on the amp it could be set way to high for the speakers.
Try upgrading your stock speakers to something newer would be the first step.
Old Sep 13, 2010 | 01:27 PM
shirk's Avatar
thats what im thinking, my amp is only for my sub
Old Sep 13, 2010 | 01:39 PM
Greedy_son's Avatar
Sounds like the stock speakers, they might only be rated at 2 ohms. Your deck might be over rated for them at 4 ohms.
Look at new 4 ohm speakers when you replace them to match your head unit.
Old Sep 13, 2010 | 03:57 PM
JRR's Avatar
JRR
stock speakers suck with load aftermarket decks. i have a couple high end alpines and when i had to use stock speakers for a few days anything above like 15 on an alpine deck just sucked horribly.
josh
Old Sep 14, 2010 | 08:55 PM
shirk's Avatar
yeah i just bought alpines today, they are pretty awesome, the stock speakers are 15 watt, and these are 240w so.... yeah, pretty nice. i still want to get a separate amp for my speakers too
Old Sep 15, 2010 | 04:51 AM
Greedy_son's Avatar
Good to hear. OEM sucks *****.
A 4 channel amp will work with the speakers and use the other amp for just the sub.
«3_Di4m0ndz»
AWD Lancer General
Feb 2, 2013 07:15 PM
Vivid Racing
EvoX 'For Sale' External Engine / Power
17
Dec 6, 2011 05:02 PM
nollij
Northwest Region
Dec 1, 2011 09:45 PM
evolvd276
Mid-Atlantic Region
Jan 16, 2010 07:53 PM
