amp cutting out in protection
Old Dec 14, 2003 | 09:23 PM
kuniboy's Avatar
if you are drawing too much power the Amp should just turn off without overload light being on. It'll just turn off and back on.
Old Dec 14, 2003 | 09:25 PM
drewskeno's Avatar
so check the speaker wire to the amp, so the speakers could cause thepower drainage? and if that is not the problem waht do you think i would need a cap or an alternator?
Old Dec 14, 2003 | 09:28 PM
drewskeno's Avatar
yea but it will like have the protectuiion light blinking then when i let the car sit for a coule days it seems to recharge itself and work agian then the same thing goes on agai nand again
kuniboy's Avatar
For now, just try wiring the speakers like I mentioned. amp + to 1st speaker + and 1st speaker - to 2nd speaker + then 2nd speaker - to amp - . try that and let us know how U did.
Old Dec 14, 2003 | 09:30 PM
kuniboy's Avatar
Remember, you're looking at 3 wires here. 2 to the amp, and 1 in between the two speakers
drewskeno's Avatar
alrite ill get back tomarrow on that but you mean the speaker wire rite goin to the amp or do you mean subs
Old Dec 14, 2003 | 09:31 PM
drewskeno's Avatar
are tse wires are already cponeccted in the amp rite ?or where would i find them
Old Dec 14, 2003 | 09:33 PM
kuniboy's Avatar
hold up let me try to draw it 4 u.
Old Dec 14, 2003 | 09:34 PM
drewskeno's Avatar
alright thank that be great
Old Dec 14, 2003 | 09:41 PM
kuniboy's Avatar
Old Dec 14, 2003 | 09:47 PM
drewskeno's Avatar
so which part fo the amp do i plug them into cause there are alot of termials like which wire the pseaker wire ? and how do i ge tto those wires?
Old Dec 14, 2003 | 09:51 PM
kuniboy's Avatar
U said is bridged rite?? so, there should only be 4 wires going into two terminals, rite? in the diagram, I showed you 2 terminals coming from the amp.
Old Dec 14, 2003 | 09:55 PM
drewskeno's Avatar
Old Dec 14, 2003 | 09:56 PM
drewskeno's Avatar
yea the subs are bridged, the diagram is the subs or car speakers?
Old Dec 14, 2003 | 09:57 PM
kuniboy's Avatar
I tried Drew! show your friend the diagram and see if they can figure it out. good luck!
