wiring between amp and speaker
Old Jan 14, 2004 | 09:38 PM
lotlot's Avatar
Hi, everyone. I've install the head unit and connect a mono amp for sub, now I have buy the second two channel amp for my speaker, how do I connect the amp and the speaker? do I need to connect another RCA's cable?
Old Jan 15, 2004 | 10:02 PM
blaze_125's Avatar
On your 2ch amp, you probably have an RCA output.
Have a RCA cable that goes from your 2ch to your mono amp.
For your front speakers, you gotta run some wires from the trunk to your front speakers.
. Mine come out of the trunk under the rear seat,
. Then they go under the carpet, under the center center console
. At the end of the center console, they each take one side
. They each go into the rubber piece that is between the frame and the door
Old Jan 15, 2004 | 11:25 PM
bobaab's Avatar
yea, and if your mono amp righ now does NOT have an RCA output, get a 2 channel amp that does have an RCA output.
here's an idea of how u should wire it if you did not have an output on the mono but do have an output on the 2 chan amp (think of this as a flow chart of the "signal" going through)
Headunit > 2 Chan > Speakers + Mono Amp > Subs
Old Jan 16, 2004 | 01:22 AM
lotlot's Avatar
thank you Blaze125 and bobaab.
domyz
Aug 18, 2016 10:08 AM
Adam Arthursson
Apr 3, 2016 12:09 PM
hexaggram
Feb 28, 2015 03:56 PM
SPOOLD
Jul 13, 2008 09:33 PM
ralliart 04 21
04-06 Lancer Ralliart How To Requests / Questions / Tips
Jun 24, 2006 07:41 AM
