video monitor
Old Apr 2, 2004 | 07:30 PM
Sirjames's Avatar
video monitor
not sure if this should be in here or audio/security but here it goes. I bought 7.2in in dash video screen from e-bay, unfortunatly it dosent have any installation instructions or wire lables on it,(bummer). I was hoping that u guys might know Im guessing the yellow av (female) is for video in, and the red one on the harness is 12v cause it has an inline fuse, but there is also a black, green, and yellow on the 4 wire harness and a also a white a/v (male).
Old Apr 2, 2004 | 07:32 PM
Sirjames's Avatar
another crappy pic via my phone
Old Apr 2, 2004 | 07:37 PM
illizit's Avatar
Hey, ok, well heres what I think they are
Yellow--->Positive from the ignition
Red------>Positive 12+ Volt
Green--->Ground
Yellow AV in--> Video In (from dvd player, ps2, etc)
White --------> Audio in (mono sound)
Hook up a dvd player to the yellow av in and the White/Red from a dvd player to your regular stereo (like in pioneer systems you can buy an adapter for the AUX port where u plug in the white/red cables to have sound) then all you do is select AUX from the stereo menu to get the sound from the dvd player or w/e you have plugged in the AUX port.
hope this helps
Old Apr 2, 2004 | 07:42 PM
Iamkar33m's Avatar
Green--->E-brake tap (to make sure u dont use the screen while ur driving)
Black---->Ground
illizit is 90% correct. Black is the ground and green is the e-brake tap.
Old Apr 2, 2004 | 07:43 PM
Sirjames's Avatar
what do u guys think about the 4th wire on the harness, there is also a black wire on it? its red (12v) yellow green and also a black? kindove weird, ive never seen one of these hooked up b4
Old Apr 2, 2004 | 07:46 PM
Iamkar33m's Avatar
read my post... black is the ground, green is the e-brake tap.
Sirjames's Avatar
sweet, i get a responce wile im typing my last question, cool, i will try to hook it up like that when it gets light. were taking my car from kentucky to disney (14hr+) trip and i want to hook my ps2 up for the kiddies
Old Apr 2, 2004 | 07:50 PM
Sirjames's Avatar
is the e-brake tap necessary or can it be bypassed. or where do i hook it up at?
Old Apr 3, 2004 | 10:35 PM
sadude's Avatar
the e-brake tap is a ground signal...if its not grounded then your TV won't work
either hook it up the right way or rig it with a switch just in case the cops pull you over u can convince them it only works if the e-brake is up
Old Apr 5, 2004 | 01:25 PM
OZrallyats's Avatar
From what I understand,
I dont think it is illegal to rig the e-brake wire, but it is provided because any shop will not install it without installing that safety feature along with it.
If anyone knows for sure whether it is actually illegal for you to gi it yourself, can you let us know, I rigged my own system that way so I am rather curious, (not that I would change it!)
Old Apr 5, 2004 | 06:41 PM
Sirjames's Avatar
Yea i see people rollin around here all the time with tv's on. Saw a dude in a olds cutlas with tv's in the headrests dash and visors. All playing wile driving. A little excessive ( i think so).
Old Apr 18, 2004 | 08:24 PM
TSi4me's Avatar
Ok first off I used to be an installer at a local shop here till I joined the cable company. The YELLOW wire needs to have a constant 12 volts, even when the car is off. The RED wire goes to ignition. Black is ground, and green is E-Brake. But like someone else said you need to ground that for the tv to work. And yes shops do ground out the brake wire, 3 different shops I have worked at did
Old Apr 21, 2004 | 02:47 PM
Sirjames's Avatar
Right on guys it worked like a charm, now I gotta watch finding nemo with my daughter everytime we go anywhere, o-well its a well worth it trade off.
Old Apr 21, 2004 | 05:49 PM
sillypuddy's Avatar
where did you get that screen from?
-joe
Old Apr 21, 2004 | 06:18 PM
Lance Dogg's Avatar
Sirjames... what did you do with the green wire? did you ground it to the same spot as the black? or did you just not use it?
