Need some help
Old Sep 10, 2002 | 01:21 AM
Kurt's Avatar
Question Need some help
I finally recieved all of my shipment from crutchfield. My question is does anyone have any suggestions for running the power wire for the amp. There are no visible holes in the firewall that I can use and I looks like its going to be a pain to drill due to all the junk on the firewall. Any suggestions will help.
Old Sep 10, 2002 | 01:22 AM
uranium9v's Avatar
I couldn't find a hole and had to drill....it's like double plated or triple plated too....have fun drillin that ****
Old Sep 10, 2002 | 01:23 AM
HobieKopek's Avatar
Everyone's drilled pretty much. Good luck.
Old Sep 10, 2002 | 01:37 AM
LancerXtreme's Avatar
Hey Hobie, hows the Infinity speakers working for ya. I went to a place and was told that the infinity speakers would be perfect for the car...
Old Sep 10, 2002 | 03:02 AM
2wdSQL's Avatar
lol I have a thread for that I should probably finish it.
How to Install an Amp Wiring Kit <------Click There
Old Sep 10, 2002 | 03:56 AM
CivicEater's Avatar
look for an existing grommet, and squeeze the wire through it.. There HAS to be a grommet with wires already!
(use some lotion or oil to lubricate the power wire, stick needle nose pliers through the grommet (around the existing wires, with the grommet popped out of the firewall) and spread the pliars open.. you should now be able to slip the power wire through.. pull it (still lubricated) through as far as you need, remove the pliers, and pop the grommet back in.. you should be good to go!
JRally
May 22, 2016 04:22 PM
bnr34rb26dett
15
Jan 21, 2011 12:09 PM
BARNSEY
Aug 27, 2007 11:15 AM
BARNSEY
Aug 27, 2007 03:36 AM
punker462606
Jun 26, 2007 05:47 PM
