Help!!!!!!!!
Old Jul 21, 2004 | 12:52 AM
03LaNcErES's Avatar
Help!!!!!!!!
my amp isent workin anymore...... i dont knoe wats seems to be the problem. i dont know if its fried ( tried to smell but my nore is playin tricks on me)everything was workin when i was drvin for a while until i parked and got back in i notice my subs wasent workin and my amp theres a red light and i rememberd it was green be4...... wats this red light mean? ............ i check everything fuse on the amp is good, wires on the speakers are good, amp is work up correctly....... the red light which is soppose to be green.... says pwr/prt...... wats prt? if any could help me get my sounds bumpin agen PLEASE?
Old Jul 21, 2004 | 01:13 AM
TeamNeXusOz's Avatar
red should be protect...basically means that its either too hot....or your blasting it too loud
Old Jul 21, 2004 | 01:17 AM
03LaNcErES's Avatar
so ish my amp fawked...... or iits workin..... so your saying is that it need to be cooled down for a while
Old Jul 21, 2004 | 01:25 AM
ya it needs to be cooled down ...i shouldnt be fawed but you wont know until it cools up and you try to run it again...im not sure how hot it is there in the 808 but in cali it gets pretty hot insdie a trunk and if you amp is not properly ventilated then it'll hot...
Old Jul 21, 2004 | 09:53 AM
blaze_125's Avatar
Red can also mean a bad ground. So if it still doesn't work once the amp is cooled down, lookup your ground connection.
Old Jul 21, 2004 | 10:39 AM
Danno's Avatar
Man I really want to be able to help you but I can't understand a word you typed. Sorry.
Old Jul 21, 2004 | 08:56 PM
03LaNcErES's Avatar
well i had another amp lying around my house and i tink its fried.... now im running low 400 watts for my 2 10"....
Old Jul 21, 2004 | 08:57 PM
03LaNcErES's Avatar
thanx for the help pple
Old Jul 21, 2004 | 08:59 PM
Lancer03oz's Avatar
Check The Fuse
Old Jul 21, 2004 | 09:22 PM
vietxscapeD's Avatar
uhmm.. red means protect and error. Your amp is by default programmed to shut off and go into protect mode when :
1 : amp gets to hot to prevent overheating
2: if you have short somewhere.
Most likely number 2 is ur cause if you've let it cool down a couple hours and its till bad.
Wire shorts are usually bad grounding... either your ground wire is loose and its making on and off contact with your ground area or you have a short in your speaker wire. From experience, u should check the area where ur speaker cables are connected to your terminal. Especially if you're not using crimps on the ends to connect to your terminals, your speaker wire ends might be frayed and if they come into contact with any other metal surface or conductive surface or if its frayed and its slightly crossing with a another speaker wire, u could have a short which would make your amp go into protect.
Old Jul 23, 2004 | 09:15 AM
PG888's Avatar
Dude i had this exact thing happen to me!!!!!!!!!!!!!!! Just one day the Amp went to protect and i couldn't figure it out. Turns out when i checked the ground wire it had sheared the bolt that was holding it to the car. I just screwed it down and er' thang was cool, I was bassin in no time!! CHECK THAT GROUND!!
Old Jul 23, 2004 | 09:21 AM
SK Lancer's Avatar
check ground and make sure your amp can handle the load you're putting on it (4ohm mono, 2 ohm, 1 ohm, etc)
Old Jul 23, 2004 | 04:41 PM
03LaNcErES's Avatar
alryte i found it was wrong my 800 watts ish back up and running thats for your folks help......
