Quick fiberglass question
Originally Posted by SK Lancer
is your back piece open to go inside and put mat in there? if it is, do that. Your outside shape is almost perfect! all you need to do is a little bondo before paint/vinyl and nothing if you're carpeting it. If you didn't leave the back side open, cut it up with a jig saw - you can seal it later with 'glass or bondo. Laying glass on the inside is always better, because like i said - it keeps your perfect shape.
If I stretch it enough, I guess I should be able to keep the same shape. Hopefully that's what's gonna happen. I don't really plan on painting it though. I think I'll just carpet it, so it looks like factory made. The only reason why I would paint is because it would be alot easier because of the shape
1) It's never easier to paint - you have to prep it...that's a LOT of work.
2) Resin will give slight sags in the material, but they'll be small if you tighten it a fair amount...
Again - cut out a hole in the back plate!!! You'll thank me later!
i dont know if you guys are done or not yet with your fiber-glass box yet but let me know how they sound.... i want to do one too... but i'm afraid that the box wont sound right or get a lot of vibration...!!!
https://www.evolutionm.net/forums/sh...ad.php?t=92017
Edit: I would post pictures of it, but it still looks the same as it did when I posted the pictures with only the t-shirt on. I guess it's a good sign, I was able to keep the shape I was aiming for.
Originally Posted by blaze_125
I already have 3 layers, but I guess 5 is better than 3 :lol
Originally Posted by livelyjay
After 4.5-5 layers all the way around my base shell, it's about 3-4mm thick and is tough as hell... For the outside layer I'm going to put about 4 layers, since that will be a load baring section holding the sub in place.
The reason why I want to put some more layers on mine is because I mixed cloth and mat. I've got half cloth half mat. It already is really hard, but I guess it's just like in bed... The harder the better
you guys are wasting money and time...
Do you ever use 2" thick MDF in sub boxes? No...you brace them. If you're that paranoid about it not being strong, 'glass some MDF braces in there...
Even easier than MDF braces, Good ol fashioned nylon rope. Soak it in some resin, toss it in the box, a criss cross pattern, and make sure it sticks where you want it.
Cheap, easy braces.
Cheap, easy braces.
Cheap, easy braces.
Cheap, easy braces.
Yes, this works too. I've done this before, but I don't even brace my 'glass boxes...there's no point...they're plenty strong.
Unless you're going 3 feet with 'glass it's hella strong...my box doesn't flex at ALL...and i have 3 layers on the back and 3+fleece on the front..
2+Fleece on the front is fine, also...
edit: After thoughts, I think I'll just slap the sub in there, make it play for a few minutes, then I'll figure out if I need another layer or not
I can't wait to see how much weight I'll be saving with that box
Last sanding step before beginning preperation (primer) should be a 500 grit sandpaper. On rough fiberglass with lotsa uneven surfaces I use a 60 grit paper then graduate to a 150 grit then a 230 grit then a 400 grit and then finally a 500 grit. This helps promote a smoother more even surface. Once primered use a 600 grit to wetsand then paint it and clearcoat then use a 1200+ grit to colorsand followed by some compound and some buffing.
