Quick fiberglass question
Old Aug 10, 2004 | 05:54 PM
  #31
blaze_125's Avatar
I'm almost done... Here's the box after 3 hours of sanding and a test fitting sub
Old Aug 11, 2004 | 04:54 AM
  #32
livelyjay's Avatar
Keep up the good work ... I should be done with mine by Sunday night this week
Old Aug 11, 2004 | 02:24 PM
  #33
blaze_125's Avatar
Well... after another hour of snading, I found a few weak spots So I had to put another layer of cloth on the box. Looks like my 4 hours of sanding was kinda worthless If everything goes right, I should be able to hear it play in a few days
Old Aug 11, 2004 | 05:04 PM
  #34
SK Lancer's Avatar
...and that's why we glass the inside.
Old Aug 11, 2004 | 06:55 PM
  #35
blaze_125's Avatar
I did consider you idea of glassing the inside, but it seemed like way too much trouble because of the shape of the box. Sanding the box in the first place had some positive impact though Because the box was already bump free, the last layer of cloth was a charm to put on. And it took me only 1 hour to sand the whole thing again .
Now the only things left are bondo and paint. Which can of bondo should I be using. Cause I've seen 2 or 3 that might do the job, but I ain't too sure which one is the right one
Old Aug 11, 2004 | 09:32 PM
  #36
SK Lancer's Avatar
But you don't have to sand! You can bondo almost instantly (only weird spots you need to sand)
Anything that's easy to sand...I usually use a harder type bondo (have no numbers for ya, man, sorry) for the bottom layer and then imperfections after that get taken out by the body man that does the rest
If you're carpeting, though, stop...no need to bondo if you're carpeting!
Old Aug 12, 2004 | 07:03 AM
  #37
livelyjay's Avatar
Exactly why I am carpeting mine
Old Aug 17, 2004 | 12:11 PM
  #38
blaze_125's Avatar
Ok, I'm no longer painting the box, I'll be carpeting. But I'm wondering how the hell I'm gonna carpet that box. Look at the shape. Will I have to cut a whole bunch of pieces and stick them on or what?
Anyone with carpet experience
Old Aug 17, 2004 | 12:17 PM
  #39
Iamkar33m's Avatar
gotta get a long peice of carpet and drape it over it. Then glue it down. Trim the hole for the sub and trim the edges. Easier said than done though
Old Aug 17, 2004 | 12:20 PM
  #40
livelyjay's Avatar
Heard a heat gun comes in handy for shaping the carpet around the enclusure.
Old Aug 17, 2004 | 12:26 PM
  #41
SK Lancer's Avatar
On carpet? Nope, you'll melt the carpet!
Old Aug 17, 2004 | 12:27 PM
  #42
blaze_125's Avatar
Then give me an idea... cause I haev no clue
Old Aug 17, 2004 | 12:33 PM
  #43
Iamkar33m's Avatar
Large roll of carpet and 3M spray adhesive
Old Aug 17, 2004 | 01:43 PM
  #44
SK Lancer's Avatar
exactly.
Don't buy trunk liner. Buy automotive carpet (there's a big diff).
Auto Carpet will stretch a bit so it will have less creases...
Old Aug 17, 2004 | 01:47 PM
  #45
blaze_125's Avatar
Alright, will try that
