Question About Sub and Amp
Old Sep 10, 2004 | 03:04 PM
TheSeige's Avatar
Well it looked like my audiobahn 8000d killed my 10in visonik sub, when i pressed in on it, it was rough going in like sand paper
so i put a new sub in, and it again stopped working, this time when pressed in on it, it was not rough, but when i pressed in far enough it seemed like the sub was getting power again and working and trying to bump like i was making contact with something making it work
any ideas?
ps i had my visonik in there for over a year, so i dont think i gave it to much power cause it was at a descent level which i usually have it on
Old Sep 10, 2004 | 04:00 PM
twardnw's Avatar
Easiest way to find out is to get another amp and hook the sub up to that.
Old Sep 10, 2004 | 04:04 PM
BillAce's Avatar
your sub is blown. You have "bottomed it out" and it's rubbing in the gap. Same as the other sub, just not as severe. Sometimes turning it on with the volume all the way up will break it free for a while. You are probably over gained and clipping your amplifier and will blow just about any sub you put in there. When you take that sub out, since it still has a good voice coil, plug it into a wall socket for some fireworks.
Old Sep 11, 2004 | 01:07 PM
TheSeige's Avatar
so what is the best way to prevent this, again?
Old Sep 11, 2004 | 08:33 PM
Higgity Hank's Avatar
Properly adjusting your gains.
Old Sep 11, 2004 | 08:41 PM
EvoVIIIGuy's Avatar
Make sure the gains are adjusted and that your crossover points are correct, The latter is not as important on a sub, but if you are really overworking your amp, you subs will never last too long because you subs is distorting constantly, (sometimes not audible) from the bad power it is getting from you amp. turn your gain down, a bit, or get a more powerful amp so your gain is not set up so high so the amp clips and sends some raw current to your sub.
Old Sep 11, 2004 | 09:17 PM
TheSeige's Avatar
ok so i have an audiobahn 8000d
and it puts out about 800 RMS but i have it turned down about 1/3 the way because the amp was 250 rms, so i should turn that knob down?
Old Sep 11, 2004 | 09:28 PM
EvoVIIIGuy's Avatar
Well if that is the case, and you had the amp gain at 1/3 the total, there are other questions I have,
What is the Max imput voltage allowed to that amp via RCA's ?
What Is the Voltage out put of your deck or line driver?
How loud was the music playing when you think the sub broke?
What Impedance were you running the sub at?
IF it is not your set up, and you fried two subs, you amp could be not working right and just eating subs for lunch. your real test would be get another amp in there just for a short time and see if it is not a problem else where, I have seen amps do funny thing with just a bad pair of RCA's or a funny wire set ups with power, ground, speaker wire etc.
It is hard to make that distinction on the web, but when **** blows up it is usualy the gain on amps or the second reason is user error or installation error.
Old Sep 13, 2004 | 06:55 AM
BillAce's Avatar
Exactly, that also isn't the highest quality amp on the market and could be outputting some DC to the speaker.
Old Sep 18, 2004 | 07:29 AM
TheSeige's Avatar
well my HU has 4v preouts
and ive never had a problem, until now, and ive had the setup for over a year
one fried when turning the car on, and the other while it was on and i was driving
ChicagoEvo9
Jun 1, 2015 07:04 PM
jjgrizz73
Mar 22, 2009 08:04 AM
J8dailo
Jul 15, 2008 03:19 PM
TazR
Jul 3, 2004 08:26 PM
ewoevo
15
Aug 13, 2003 09:40 PM
