Custom Fiberglass enclosure in trunk PIX!!
5 Attachment(s)
Just finished makin fiberglass enclosures for each corner in my trunk. I still gotta carpet them but heres what i got so far...
Def. post pics when you get it completed. Are you planning on cleaning up those wires?
{thumbup} on the enclosures, but {thumbdwn} on the taped and loomed wire. :)
How are you going to mount your amps? |
hey that box looks just like mine!
why you running different types of subs on one system ?
Probably with different amps too. can you say Cancellation?
do you have interior speakers? alot of pple just get subs and i think it sounds terrible.. well around here atleast.. they think if u get subs that r loud than u have an amazing system. clarity and balance is what makes a system but everything looks great. post pics when there done. and get rid of those wires :thumbup:
That looks really good, and I'm sure it's gonna look even better when you're done with it =) One thing. You should use the same subs all around. Otherwise, the bass won't be even and you could be missing out on the full potential on your setup.
pley glass over the amps will look nice but i dk about red neon lights.. maybe just blue will be nice... u should drill a lil hole behind the w3 sub and have the wires goin thru there and draw 2 smole holes so u ca pop out the wires to the 2 kicker subs..have the wires running under the carpeting ya kno.
sorry i mean. drill a hole by the amp and have all the wires go thru it, drill a small hole behind the kickers so u can connect em and a small hole behind the w3 so all ur wires will be under the carpet.. i thin u said u relaly don't want to drill holes but i think its da best way to go.. it will look amazing when its done with no wires hanging aorund ya kno. u should put a board over the amps with plexy glass window showing the amp with blue neon lights.. that will loook insane
