Custom 'carputer' fabrication // car audio build thread
35 Attachment(s)
doncarbone's Custom Car PC
Introduction 22yo webmaster and computer geek...decided some time ago to attempt to get a working computer in my 2003 OZ rally (will soon be doing 2.4L 4G69 swap!) as I wanted to listen to music from my iTunes and maybe put on the odd movie on long trips. There are of course many other reasons I wanted a computer in my car. A brief back story... Over a year ago, I started by mounting a cheap 3G netbook onto the dash. I bent some aluminum to craft a monitor stand which held in place a 10" netbook laptop which had the monitor flipped the opposite way around (so the keyboard/base was behind the monitor on the dash). I powered this with a 300W inverter and connected the laptop's sound to an AUX-in on a single pre-out JVC head-unit that I bought for around $50. Since then, and after being laughed at by passengers, I've decided to try and do something a little more 'complete' and higher quality. So that being said, let me present to you my work-in-progress car computer build! Components/Materials: - Kinetik HC1400 power cell (front/starter) - Kinetik HC800 power cell (rear auxiliary) - Stinger 300amp isolator - 10.2" Xenarc 1020TSV touchscreen monitor - 300W inverter (from before, will power the monitor and be used for misc) - Griffin Powermate programmable dial - Opus Solutions 350W 12V power supply - PC with 4GB DDR3 ram, Dual Core 2.4Ghz athlon cpu, 120GB solid state drive, Creative X-Fi sound card + two 120mm blue led fans (fabricated in trunk) - Focal 165A1 components/tweeters - Focal 165CA1 coaxials - Two 10" Image Dynamics IDQ10V3 2ohm subwoofers - Hertz EP4X 4-channel amplifier (150W x 4) - Alpine MRP-MR1000 Monoblock amplifier (500+ x 2) - Dynamatted the entire interior/trunk/doors - Applied 0.5" thick neoprene foam throughout the vehicle to absorb road/engine noise - Two 60mm Prosport volt gauges (for each battery) - 3-way USB hub - key/lockable LED valet switch for PC power Pictures: Attachment 336838 Removed entire dash panel / climate control / stereo / trim, two PVC pipes where gauges will eventually go. At this point i was Noob Level I. Attachment 336839 Metal screen frame glued in place and fleece fabric stretched over top...i think at this point i said to myself more than once "what the **** am i thinking?" Mixed my first ever batch of fiberglass resin for this step. Attachment 336840 Glued the frame in place, cut mold Attachment 336841 "Well it will look strange if the rest of the panels dont match?" - ah screw it so started smearing fiber-enforced filler across. :lol: Attachment 336842 Starting to take shape, added the gauge pods above Attachment 336843 Sanded a bit and testing fitment...decided to have it stretch overtop the instrument/gauge cluster above steering wheel Attachment 336844 Wish i took some pics between this pic and the last, added in USB ports from hub, hole for valet switch, hazard light and 2 component switches Attachment 336845 Primed and sanded, still lots of dents and scuffs Attachment 336846 painted, bit too glossy, I have since applied quite a few layers of dead flat toner Attachment 336847 stripped interior, time for dynamat -__- Attachment 336848 have dynamatted the entire floor, front doors, trunk and doubled up on trunk lid Attachment 336849 Attachment 336850 Attachment 336851 Neoprene, 1/8" strips glued together, this particular piece went in the door. Couldnt find thicker neoprene from a Canadian dealer, so went with the only roll on amazon.ca (1/8") Attachment 336852 Now to move the climate control panel Attachment 336853 i hate working with this stuff Attachment 336854 -__- Attachment 336855 bit better Attachment 336856 in the meantime, will spray on some toner Attachment 336857 looks a lot better, i think since taking this pic ive used more toner Attachment 336858 new battery, 0 gauge, inline fuses and isolator all fixed in place Attachment 336859 all internal wiring fed underneath the carpet, two USB extenders, monitor cable, monitor power cable and 0 gauge from front to rear battery fed through Attachment 336860 Attachment 336861 side note, since i spilled resin on my front seats and they are pretty poor seats in the OZ rally, i bought these new ones! very comfortable and the bolster support is great! (in anticipation for the 4G69 + mods) Attachment 336862 climate control relocation starting to come together Attachment 336863 painted, still needs toner to match dash Attachment 336864 more madness! filled over where ash tray used to be, time to get the griffin dial mounted Attachment 336865 angled base toward driver, griffin pictured top Attachment 336866 light guard and some finish (this dial has a very bright blue LED on its base, i wanted to contain it a bit with a guard) Attachment 336867 getting the guard in place Attachment 336868 what a mess Attachment 336869 cleaned up a bit, good ol' bondo Attachment 336870 spot putty and some sanding Attachment 336871 primed, griffin in place, will be attaching it to the base via velcro Attachment 336872 And there we have it, that's all I have for now, will update as I go! - Don |
this looks awesome... sub'd for the finished product.
don't crap out on this and let me down. |
Originally Posted by Chaz17
(Post 10228689)
don't crap out on this and let me down. will update as often as possible |
4 Attachment(s)
Found some time today to paint the climate control mold and the mold around shift boot..also velcro'd the griffin powermate in place too
Attachment 336799 Attachment 336800 looks a lot better with the toner on it Attachment 336801 oh ya this notch in the top left is for the wire, less of a hump for the wire, will make for a cleaner install Attachment 336802 will be interesting to see it illuminate once in car i'll have both these in the car tomorrow |
1 Attachment(s)
I wish I had the materials/money/will power to do something like this...it looks awesome
Originally Posted by MarkChamorro
(Post 10242093)
I've cut corners money-wise where I was able to...PC was built mainly from old, scrap parts from previous PC builds, fiberglass and filler i've used is basically the stuff you get at Canadian tire (no special/premium stuff)...borrowed a friend's air compressor and die-grinder...USB cables and all wiring I bought from www.monoprice.com ..speakers/amps, dynamat on sale from a www.woofersetc.com, paint from industrial paint and plastic, local store that mixed the paint for me at a good price. this project has been on-and-off for around a year now, only recently have I been going strong again working on it consistently, so i've definitely had time to save money and find the right components |
6 Attachment(s)
update:
have attached to the mold bolts to connect to dash securely. bolts are held in place with JB weld front/back and lock washers Attachment 336685 Attachment 336686 Since doing this I've filled over holes/scruffs on front, painted, applied toner: Attachment 336687 Attachment 336688 pc power switch (not mounted yet), monitor switches, usb ports visible but they need work, might see about painting around edges or getting some sort of trim for that Attachment 336689 as well as 3 bolts on right side that have been stealthily hidden, I had to drill 2 bolt holes on the left. Attachment 336690 u can't see these bolts, basically out of view and sort of behind the steering wheel...but just to make it cleaner i'll paint em to match dash and see if i can clip on a plastic covering more to come soon! |
1 Attachment(s)
Another of hazard light switch:
Attachment 336684 going to see if i can find a stencil or sticker for the hazard light emblem |
Made a quick video:
1 Attachment(s)
1 Attachment(s)
another angle, tested calibration on touch (5-wire resistive), calibrated at 9 points, working great so far!
Attachment 336675 |
1 Attachment(s)
That looks really good! I was really tempted to do something like that, but because I didn't have the time I just doubt a single din pop-out screen and didn't worry about it.
3 Attachment(s)
so far this weekend been working on the trunk:
Attachment 336573 3/4" mdf, battery holder to keep it from moving (thing is so tight i can barely get the battery back out lol)...will add trunk floor on top of frame, underneath are all my components, small latch eventually to get to spare tire Attachment 336574 Attachment 336575 comp will sit on this side, will make a custom fiberglass casing for it and connect in-take and exhaust fans |
