Custom 'carputer' fabrication // car audio build thread
Old Jun 17, 2012 | 10:47 PM
doncarbone's Avatar
doncarbone's Custom Car PC
Introduction
22yo webmaster and computer geek...decided some time ago to attempt to get a working computer in my 2003 OZ rally (will soon be doing 2.4L 4G69 swap!) as I wanted to listen to music from my iTunes and maybe put on the odd movie on long trips. There are of course many other reasons I wanted a computer in my car.
A brief back story... Over a year ago, I started by mounting a cheap 3G netbook onto the dash. I bent some aluminum to craft a monitor stand which held in place a 10" netbook laptop which had the monitor flipped the opposite way around (so the keyboard/base was behind the monitor on the dash). I powered this with a 300W inverter and connected the laptop's sound to an AUX-in on a single pre-out JVC head-unit that I bought for around $50. Since then, and after being laughed at by passengers, I've decided to try and do something a little more 'complete' and higher quality.
So that being said, let me present to you my work-in-progress car computer build!
Components/Materials:
- Kinetik HC1400 power cell (front/starter)
- Kinetik HC800 power cell (rear auxiliary)
- Stinger 300amp isolator
- 10.2" Xenarc 1020TSV touchscreen monitor
- 300W inverter (from before, will power the monitor and be used for misc)
- Griffin Powermate programmable dial
- Opus Solutions 350W 12V power supply
- PC with 4GB DDR3 ram, Dual Core 2.4Ghz athlon cpu, 120GB solid state drive, Creative X-Fi sound card + two 120mm blue led fans (fabricated in trunk)
- Focal 165A1 components/tweeters
- Focal 165CA1 coaxials
- Two 10" Image Dynamics IDQ10V3 2ohm subwoofers
- Hertz EP4X 4-channel amplifier (150W x 4)
- Alpine MRP-MR1000 Monoblock amplifier (500+ x 2)
- Dynamatted the entire interior/trunk/doors
- Applied 0.5" thick neoprene foam throughout the vehicle to absorb road/engine noise
- Two 60mm Prosport volt gauges (for each battery)
- 3-way USB hub
- key/lockable LED valet switch for PC power
Pictures:
Custom 'carputer' fabrication // car audio build thread-k27tsh.jpg
Removed entire dash panel / climate control / stereo / trim, two PVC pipes where gauges will eventually go. At this point i was Noob Level I.
Custom 'carputer' fabrication // car audio build thread-tevlbh.jpg
Metal screen frame glued in place and fleece fabric stretched over top...i think at this point i said to myself more than once "what the **** am i thinking?" Mixed my first ever batch of fiberglass resin for this step.
Custom 'carputer' fabrication // car audio build thread-f8ojmh.jpg
Glued the frame in place, cut mold
Custom 'carputer' fabrication // car audio build thread-61iiyh.jpg
"Well it will look strange if the rest of the panels dont match?" - ah screw it so started smearing fiber-enforced filler across.
Custom 'carputer' fabrication // car audio build thread-wpucyh.jpg
Starting to take shape, added the gauge pods above
Custom 'carputer' fabrication // car audio build thread-cydeoh.jpg
Sanded a bit and testing fitment...decided to have it stretch overtop the instrument/gauge cluster above steering wheel
Custom 'carputer' fabrication // car audio build thread-rqqtgh.jpg
Wish i took some pics between this pic and the last, added in USB ports from hub, hole for valet switch, hazard light and 2 component switches
Custom 'carputer' fabrication // car audio build thread-ydax1h.jpg
Primed and sanded, still lots of dents and scuffs
Custom 'carputer' fabrication // car audio build thread-vd8iv.jpg
painted, bit too glossy, I have since applied quite a few layers of dead flat toner
Custom 'carputer' fabrication // car audio build thread-jgw6ch.jpg
stripped interior, time for dynamat -__-
Custom 'carputer' fabrication // car audio build thread-jkpkrh.jpg
have dynamatted the entire floor, front doors, trunk and doubled up on trunk lid
Custom 'carputer' fabrication // car audio build thread-klohfh.jpg
Custom 'carputer' fabrication // car audio build thread-ihrysh.jpg
Custom 'carputer' fabrication // car audio build thread-haenmh.jpg
Neoprene, 1/8" strips glued together, this particular piece went in the door. Couldnt find thicker neoprene from a Canadian dealer, so went with the only roll on amazon.ca (1/8")
Custom 'carputer' fabrication // car audio build thread-ahjxoh.jpg
Now to move the climate control panel
Custom 'carputer' fabrication // car audio build thread-aopejh.jpg
i hate working with this stuff
Custom 'carputer' fabrication // car audio build thread-jmwfhh.jpg
-__-
Custom 'carputer' fabrication // car audio build thread-iuc1oh.jpg
bit better
Custom 'carputer' fabrication // car audio build thread-buxknh.jpg
in the meantime, will spray on some toner
Custom 'carputer' fabrication // car audio build thread-u25oyh.jpg
looks a lot better, i think since taking this pic ive used more toner
Custom 'carputer' fabrication // car audio build thread-gjbmyh.jpg
new battery, 0 gauge, inline fuses and isolator all fixed in place
Custom 'carputer' fabrication // car audio build thread-uuookh.jpg
all internal wiring fed underneath the carpet, two USB extenders, monitor cable, monitor power cable and 0 gauge from front to rear battery fed through
Custom 'carputer' fabrication // car audio build thread-yjsb0h.jpg
Custom 'carputer' fabrication // car audio build thread-zid1dh.jpg
side note, since i spilled resin on my front seats and they are pretty poor seats in the OZ rally, i bought these new ones! very comfortable and the bolster support is great! (in anticipation for the 4G69 + mods)
Custom 'carputer' fabrication // car audio build thread-kg5nrh.jpg
climate control relocation starting to come together
Custom 'carputer' fabrication // car audio build thread-wgr7oh.jpg
painted, still needs toner to match dash
Custom 'carputer' fabrication // car audio build thread-e9ywth.jpg
more madness! filled over where ash tray used to be, time to get the griffin dial mounted
Custom 'carputer' fabrication // car audio build thread-wco7yh.jpg
angled base toward driver, griffin pictured top
Custom 'carputer' fabrication // car audio build thread-c5dcyh.jpg
light guard and some finish (this dial has a very bright blue LED on its base, i wanted to contain it a bit with a guard)
Custom 'carputer' fabrication // car audio build thread-s2ttbh.jpg
getting the guard in place
Custom 'carputer' fabrication // car audio build thread-23tvmh.jpg
what a mess
Custom 'carputer' fabrication // car audio build thread-zjvy4h.jpg
cleaned up a bit, good ol' bondo
Custom 'carputer' fabrication // car audio build thread-pwrubh.jpg
spot putty and some sanding
Custom 'carputer' fabrication // car audio build thread-7wtbhh.jpg
primed, griffin in place, will be attaching it to the base via velcro
Custom 'carputer' fabrication // car audio build thread-u6mueh.jpg
And there we have it, that's all I have for now, will update as I go!
- Don
Old Jun 17, 2012 | 10:55 PM
Chaz17's Avatar
this looks awesome... sub'd for the finished product.
don't crap out on this and let me down.
Old Jun 18, 2012 | 01:27 AM
doncarbone's Avatar
thank you!
will update as often as possible
Old Jun 23, 2012 | 10:57 PM
doncarbone's Avatar
Found some time today to paint the climate control mold and the mold around shift boot..also velcro'd the griffin powermate in place too
Custom 'carputer' fabrication // car audio build thread-zcpukh.jpg
Custom 'carputer' fabrication // car audio build thread-pikwoh.jpg
looks a lot better with the toner on it
Custom 'carputer' fabrication // car audio build thread-nqqpkh.jpg
oh ya this notch in the top left is for the wire, less of a hump for the wire, will make for a cleaner install
Custom 'carputer' fabrication // car audio build thread-x0c2dh.jpg
will be interesting to see it illuminate once in car
i'll have both these in the car tomorrow
Old Jun 23, 2012 | 11:59 PM
doncarbone's Avatar
Another one of climate control with stickers on:
Custom 'carputer' fabrication // car audio build thread-dhboch.jpg
Old Jun 24, 2012 | 03:50 PM
MarkChamorro's Avatar
I wish I had the materials/money/will power to do something like this...it looks awesome
Old Jun 24, 2012 | 09:38 PM
doncarbone's Avatar
Thanks man.
I've cut corners money-wise where I was able to...PC was built mainly from old, scrap parts from previous PC builds, fiberglass and filler i've used is basically the stuff you get at Canadian tire (no special/premium stuff)...borrowed a friend's air compressor and die-grinder...USB cables and all wiring I bought from www.monoprice.com ..speakers/amps, dynamat on sale from a www.woofersetc.com, paint from industrial paint and plastic, local store that mixed the paint for me at a good price.
this project has been on-and-off for around a year now, only recently have I been going strong again working on it consistently, so i've definitely had time to save money and find the right components
Old Jul 11, 2012 | 04:23 PM
doncarbone's Avatar
update:
have attached to the mold bolts to connect to dash securely. bolts are held in place with JB weld front/back and lock washers
Custom 'carputer' fabrication // car audio build thread-xatqmh.jpg
Custom 'carputer' fabrication // car audio build thread-mhkjbh.jpg
Since doing this I've filled over holes/scruffs on front, painted, applied toner:
Custom 'carputer' fabrication // car audio build thread-isvimh.jpg
Custom 'carputer' fabrication // car audio build thread-wwjxxh.jpg
pc power switch (not mounted yet), monitor switches, usb ports visible but they need work, might see about painting around edges or getting some sort of trim for that
Custom 'carputer' fabrication // car audio build thread-5xnzch.jpg
as well as 3 bolts on right side that have been stealthily hidden, I had to drill 2 bolt holes on the left.
Custom 'carputer' fabrication // car audio build thread-mq4n5h.jpg
u can't see these bolts, basically out of view and sort of behind the steering wheel...but just to make it cleaner i'll paint em to match dash and see if i can clip on a plastic covering
more to come soon!
Old Jul 11, 2012 | 04:27 PM
doncarbone's Avatar
Another of hazard light switch:
Custom 'carputer' fabrication // car audio build thread-nobnwh.jpg
going to see if i can find a stencil or sticker for the hazard light emblem
Old Jul 12, 2012 | 01:05 AM
doncarbone's Avatar
Made a quick video:
Old Jul 12, 2012 | 07:10 PM
doncarbone's Avatar
Today tested mounting of touch screen and usb hub - all working great so far!
Custom 'carputer' fabrication // car audio build thread-h8izu.jpg
Old Jul 12, 2012 | 08:39 PM
doncarbone's Avatar
another angle, tested calibration on touch (5-wire resistive), calibrated at 9 points, working great so far!
Custom 'carputer' fabrication // car audio build thread-nncnd.jpg
Old Jul 27, 2012 | 06:53 PM
doncarbone's Avatar
Haven't made an update for some time...been waiting on this mess to arrive:
Custom 'carputer' fabrication // car audio build thread-bxmei.jpg
Old Jul 28, 2012 | 01:07 PM
03Silver's Avatar
That looks really good! I was really tempted to do something like that, but because I didn't have the time I just doubt a single din pop-out screen and didn't worry about it.
Old Jul 28, 2012 | 06:40 PM
doncarbone's Avatar
so far this weekend been working on the trunk:
Custom 'carputer' fabrication // car audio build thread-oceza.jpg
3/4" mdf, battery holder to keep it from moving (thing is so tight i can barely get the battery back out lol)...will add trunk floor on top of frame, underneath are all my components, small latch eventually to get to spare tire
Custom 'carputer' fabrication // car audio build thread-is5ut.jpg
Custom 'carputer' fabrication // car audio build thread-kqrgk.jpg
comp will sit on this side, will make a custom fiberglass casing for it and connect in-take and exhaust fans
