~Bad Idle after installing PB~
Old Jun 27, 2006 | 12:46 PM
DANERS_03's Avatar
Unhappy ~Bad Idle after installing PB~
Hey everyone~
I just got done installing my PB ECU that i bought from a member here on the boards.
Now here's my delema.....I got the unit with just the unit, a R4 Engine Management CD, and the Stage 2 Map Cd, no extra tubing and no T-fitting for the vacuum line. So, i went to the local parts store picked up some tubing and a T-fiitting. Got back hooked up all wires and vacuum line. reconnected the battery and started the car.
Now, on the instructions sheet it said that you might notice a high Rev., but i had just the opposite. I had an extremely low rev., like 500 rpm. and after about 30 sec. the car died. So i repeatedly started the car again about 5 times and it did the same thing. i went and checked out all my wiring and everything is hooked up correctly. Does anyone have any idea what i did wrong, or how i can fix this?? i need HELP!! Thanks in advance
OH i don't know if this will help but here's my mod list:
RRM stage 1 turbo kit
walbro fuel pump
big bore fuel rail
vortech fmu
new RC injectors
stage 2 clutch
Please let me know with anything that you guys know!!
Old Jun 27, 2006 | 07:57 PM
SLVROZ_03's Avatar
You might want to try reloading the stage 2 map again onto the piggy. Maybe it had a bad transfer... Why did the previous owner get rid of it? Is this a v.2 piggy, or an upgraded v.1?
Old Jun 27, 2006 | 08:10 PM
thcomb's Avatar
there isn't a v.2 for a turbo application. also the vacume line gives it away. redo all of you connections.
Old Jun 28, 2006 | 01:07 PM
DANERS_03's Avatar
I talked to a guy at RRM and he said the reason why the idle is so weak is because it's programmed for stage 2 application. I think the only other thing i really need is bigger injectors and then i'll be ok.
You guys got a suggestion for optimum injector size for stage 2?
Old Jun 28, 2006 | 01:25 PM
Wallesasuaz's Avatar
u should have asked RRM. they'll tell you what their injector size are for their stage 2.
Old Jun 28, 2006 | 03:58 PM
ROCK's Avatar
There is more than just map and injectors to Stage 2. Ther are other mods in order to make it idle properly but I guess you have everything so you know that. What size injectors do you have?
ROAD/RACE
