Piggy back Fuel maps...
Old Dec 5, 2006 | 09:08 AM
Mirage2.0's Avatar
If I would just send you the ecu, would that help? I would love to get your piggy.
Old Dec 5, 2006 | 11:43 AM
SilvOzRallEdit's Avatar
oink oink
Old Dec 5, 2006 | 12:12 PM
CoreyJBarron's Avatar
Rock, what would it cost to send in my v2 piggy for a reflash with gabe's tune you were talking about? Or that one wouldn't work on an auto?
Old Dec 5, 2006 | 12:31 PM
jakermeister's Avatar
I think there still tuning it. He posted a little bit of it in the lancer vendor forum. I think he said it might be done by thursday. L8tr
Old Dec 5, 2006 | 12:41 PM
blaze_125's Avatar
If you baught the software, it should cost as much as it costs to send an email with attachement.
Old Dec 5, 2006 | 04:20 PM
wh wont your version 1 map work with verion 2?
Old Dec 5, 2006 | 05:39 PM
ROCK's Avatar
One calibrates on RPM and Pressure. The other RPM and voltage. They are very different maps.
ROAD/RACE
Old Dec 5, 2006 | 07:48 PM
Mirage2.0's Avatar
Old Dec 5, 2006 | 07:54 PM
ROCK's Avatar
No we could not get it done with just the ECU.
ROAD/RACE
Old Dec 5, 2006 | 08:00 PM
Mirage2.0's Avatar
Thanks anyway.
Old Dec 5, 2006 | 09:56 PM
I didn't buy the software or the cable...maybe I should, because I have a laptop I could hook up to it if i had the cable.
Old Dec 7, 2006 | 10:04 AM
Just be sure to save your original settings.
Old Dec 7, 2006 | 11:33 AM
blaze_125's Avatar
ROAD/RACE
Thanks for answering
Here's a quick question. I think I already know the answer, but I'll ask in case the answer is different.
What would happen if we simply changed the System Setting from "Vacuum/Pressure" to "Volatge" and keep the same values. If I do so, all my values are still the same in the same cells.
Are the V values directly proportional to the Hg values?
Is -27,5Hg equal to 0,7V?
I'm asking because no matter what setting is used, the map still displays the same amount of cells on both axis.
Old Dec 7, 2006 | 01:59 PM
ROCK's Avatar
IT might work but it shouldn't work if that makes sense. Piggy system is sensitive. That is what make a piggyback better than AFC etc... But it also makes it not like to swap over values etc like you would like.
ROAD/RACE
