ecuflash load tuning
Old Nov 30, 2007 | 12:10 PM
  #31
TouringBubble's Avatar
Originally Posted by lancerrally45
Injector Scaling - Stock is set @ 513 for USDM cars. End user must re-scale injectors when using bigger aftermarket injectors. Rule of thumb is: the number in the table should be 10-15% smaller than the actual injector size. End user must log fuel trims to make sure that the number in the table is accurate. Fuel trims must be kept between +/-5.
(i know thats for the evo but i think it would still mean the same thing for our cars.)
https://www.evolutionm.net/forums/sh...ling+injectors
This is 100% correct. However, it doesn't say to scale lower than the actual value to keep duty cycle down. You scale lower because of how the ECU calculates fuel for closed loop. If you were to scale, say, 650 cc injectors at 650, you would be initially lean and the ECU would increase fuel trims to compensate. By lowering that value, you can keep trims near 100 (0).
Old Nov 30, 2007 | 12:11 PM
  #32
EvoScan should be between 90 and 110, and Mitsulogger should be between -10 and 10.
(The quote you posted says within 5%, but I've found that a dirty air filter can skew the trims by 15% or more, so i think 10% is okay)
Old Nov 30, 2007 | 12:12 PM
  #33
lancerrally45's Avatar
alright that makes sence, thanks for clearing that up for me. so if i click on my LTFT low mid and high what should i see on the maps. cuz im looking at them right now
Old Nov 30, 2007 | 12:15 PM
  #34
and if they are off what would this cause?
Old Nov 30, 2007 | 12:34 PM
  #35
If they get too far off, the ECU can no longer control the fuel mix in closed loop. Also, on the Evo's at least, the fuel trims will sometime affect open loop (WOT) fueling as well. this is a pain because the trims reset after flashing. So, you tune your AFRs dead on after a couple of flashes, but then the trims stack up and your AFR at WOT changes.
Old Nov 30, 2007 | 12:37 PM
  #36
so all of the fuel trims should be within that 90-110? low mid and high?
Old Nov 30, 2007 | 12:47 PM
  #37
Yes. The High trim is usually stays at 100 in EvoScan because it applies changes at airflow values so high that you are usually in open loop when they occur.
Originally Posted by TouringBubble
An update on some things I've noticed while tuning the MAF scaling ...
It seems that the low trim is related to low air flow readings ... usually below 75 Hz ... idle air flow essentially. Mid Trim seems to affect 100 Hz to 500 Hz areas (cruise) and High Trim is everything above 500 Hz.
High Trim doesn't change often because we are usually in open loop at or above 500 Hz. Mid Trim is usually less skewed because the air flow tends to be less erratic once the velocity increases ... this is another reason that High Trim isn't often skewed. Low Trims are usually affected the most by a modified air intake because the flow is so much different at low, idle air speed.
** This quote was referring to MAF scaling and not injector scaling ... both can affect fuel trims. **
Old Nov 30, 2007 | 12:51 PM
  #38
kungfugirl's Avatar
SO is tis in reference to maf modding? like the removal of the restricor plate
Old Nov 30, 2007 | 12:58 PM
  #39
alright, well that sucks then. haha cuz mine are off, but i havent seen anything telling me that they were off in my afrs at wot. whats the best way to change it? rescale to 400? and redue the fuel maps? or rescale, log the stock maps back on then edit them? im confused. thanks bubble
Old Nov 30, 2007 | 01:26 PM
  #40
Modifying the intake box/filter/etc can throw off MAF readings which can throw off the fuel trims (the MAF reading is the "Air" part of the "Air to Fuel" Ratio of course). The Hz values mentioned relate to where the fuel trims take effect per the MAF scaling table. The stock MAF scaling table isn't in Hz, but you can simply divide the left column values by 10 to get a ball park Hz value.
So, if your trims are off, it could be caused by injectors or MAF readings. the only way to know is to use known injector scalings and adjust the MAF scaling, or adjust MAF scaling with the stock injectors and then add your larger injectors and scale them as well. This makes for a tricky predicament, because lots of stuff is based on that MAF reading, and if you adjust your injector scaling to compensate for what is really an airflow issue you could likely have a problem you are just covering up.
Old Nov 30, 2007 | 01:35 PM
  #41
That's because trims (for the most part) only affect closed loop. As I said, you can tune the map to get rid of the rich condition in open loop, but correcting it in closed loop can only be done by correctly scaling the injectors.
The fix is to set a conservative fuel map, perhaps based on the stock map -2 AFR or so. Then, scale your injectors per the ECUFlash injector scaling tutorial. After that is done, tune your fuel map.
Just a note: it takes a while for the fuel trims to settle where they want to be. So, after the initial scaling, drive around for a couple of days before checking the trims again. The trims will only move while you are in closed loop, so watch the O2 Feedback Trim to get a feel of where your crossover point is. If you use my gauge set with EvoScan it has a closed loop indicator just above the AFR value.
Old Nov 30, 2007 | 01:41 PM
  #42
alright thanks for the help
Old Nov 30, 2007 | 01:43 PM
  #43
No problem. I do what I can.
Old Nov 30, 2007 | 01:56 PM
  #44
alright so this is my plan. just to clearify before i start doing it.
im going to leave my moded timing maps because they are fine.?
im putting stock fuel maps (low and high) back on and droping all values 2 afrs
scale injectors to 390
then go out and tune the fuel maps?
Old Nov 30, 2007 | 03:17 PM
  #45
if 390 is about 15% below your actual injector size, then yes. Read some of the threads on injector scaling before heading out to try this. You may need to adjust the latency as well to get the mid fuel trims in check. You aren't going too big so it might not be an issue.
Just so we are clear, 2 AFR is 2.0. That should put most of the WOT values at ~10.0. If your actual AFRs are below 10.0:1, abort and bump up the fuel map ... there is a such thing as too rich. If you have an FMU installed, you might want to put the fuel map around 11.0 since it will be adding fuel as well.
Then, just tune like you normally would, of course logging knock. And you might want to make a pass with real time gauges running to catch any knock early. You may need to adjust timing slightly to avoid knock during tuning, but if you get the AFR's to match what they were before, you will not have to change the timing map.
