OK ecu flash switch from piggy, help
Old Aug 12, 2008 | 12:54 AM
cantcatchme96's Avatar
Registered User
Okay I've been reading for hours on this, and I downloaded it, and I'm going to order the cable tomorrow, I have a t3 turbo 02 lancer 550injectors and piggy....I'm sure this has been around for sometime, so is there some guys on here with similiar turbo setups that have maps I can just copy and then adjust from there? Thanks!
Old Aug 12, 2008 | 12:43 PM
Ozturbo's Avatar
I have 560 cc injectors, t 25, 11 psi, running pretty decent. I just tuned this weekend and I am finally getting no readable knock in my logs, 11.3- 10.9 afr's ( on the rich side, but is ready for fine tuning once I figure out my wideband issue). I would suggest just tuning with a wideband, after I got my car to idle it was pretty easy to tune. I think I have my injector scaling at 440. You will need to adjust your Injector battery latency to get the car to idle. I can check what I set mine to later. I think I dropped the ms some.
Old Aug 12, 2008 | 12:45 PM
Ozturbo's Avatar
Oh, also adjust the latency for 14.06 volts.
Old Aug 12, 2008 | 01:48 PM
Registered User
Lol, ok thank you, I'm going to have to get a bit more handy w/ the software first, but can you tell me why we HAVE to use the tantrix or w/e it is cable, why wont any obd2 to usb cable work? thanks a lot
Old Aug 14, 2008 | 11:54 AM
Ozturbo's Avatar
I honestly don't know the cable appears to just break out the connections from the usb to an obdII pin, but I don't want to rip my cable apart to find out. But for the cost of evoscan and the cable you can't go wrong.
Old Aug 15, 2008 | 11:38 AM
Registered User
ok im going to check it out and get back to you, thanks
xelAFeVo
Lancer Engine Tech
Apr 25, 2014 07:07 PM
0wnZrd
Nov 10, 2013 03:16 PM
Lancer GT
Lancer Engine Management / Tuning Forums
Jul 7, 2013 11:05 PM
dadsgts
Jul 7, 2013 09:54 PM
evo-boy
11
Jan 13, 2006 08:38 AM
