EcuFlash...wrx 440s shut off at idle???
Old Sep 18, 2008 | 12:33 AM
sykou's Avatar
Angry EcuFlash...wrx 440s shut off at idle???
So i got some wrx 440s tuned in with ECUflash and it idles fine, the fuel trims are pretty good but the only problem is that when i let off the throttle and press the clutch in while coming to a stop, say in slow moving traffic, my afrs will drop to about 20ish(which is off BTW) and then bounce back to 14ish and then back and forth a few times before coming bak to a steady idle of around 14.3-15 AFR... I have no partial throttle issues or WOT issues... I think it may be something to do with the injector latencies but i dont know which direction i should go with it(add to the latency values or subtract from them)?? hope someone can be of some help... thanks in advance!
Old Sep 18, 2008 | 09:25 PM
sykou's Avatar
nobody?
Old Oct 16, 2008 | 11:14 PM
Complink's Avatar
the ecu will employ fuel cut at no throttle above 1500 rpm. but if its doing this below that then you may have a latency issue. I think you increase the latency value to increase fuel since it will open sooner. someone correct me if im wrong.
Old Oct 16, 2008 | 11:16 PM
Magnumpsi's Avatar
Try and increase the latency at 12-14volts by just a bit and see if that helps. My guess is you will benefit from a little bit of extra fuel there.
Mitch
Old Oct 19, 2008 | 12:38 AM
sykou's Avatar
will try that out...Should i just increment it once or should i add a certain percentage??
Old Oct 24, 2008 | 07:24 AM
TouringBubble's Avatar
Don't increment latencies ... bump up by .02 or so each time. Manually enter the value.
Fast_Freddie
Oct 30, 2023 01:56 AM
burner67
Lancer Engine Management / Tuning Forums
Nov 14, 2012 09:53 AM
b16a95eg
Dec 31, 2010 08:08 AM
sykou
Lancer Aftermarket Forced Induction Tech
36
Oct 8, 2008 03:02 AM
