Gauges that are important!!!
Old Jan 7, 2009 | 06:03 PM
smoke's Avatar
I got a 08 lancer and i do a LOT of driving. my current mods are: lowering springs, shortram intake, crankshaft pulley.
i drive an average of 50 kilometers a day, and i do trips as well crossing the USA border.
i want to keep this car N/A!!!!! i want to get a header, and exhaust and change to a fidanza flywheel.
but i do want to have gauges to monitor this car. which are the most recommended for me? some friends told me this list because the winters are cold and the summers are hot in where i live :
oil temp gauge
water temp
fuel pressure
do those seem about right? i want to put it on a 3 gauge holder on the center dash.
Old Jan 7, 2009 | 06:56 PM
nj_08_gts's Avatar
If you have to pick between the two, I'd say oil pressure rather than oil temperature. They're both important, but driving a track car, I care more about oil pressure (or sometimes the lack thereof) than what the temperature is.
Old Jan 7, 2009 | 07:01 PM
TRASHY_GTS's Avatar
Oil Pressure
Old Jan 8, 2009 | 10:51 AM
Stuntfly02's Avatar
Air/Fuel ratio, and Oil pressure would be what I would go with. You can see water temp via the existing display, I'de say oil temp isn't as important unless you spend a lot of time on a track. If you are racing and your oil starts to boil you are in trouble. And if u are having fuel pressure issues you will now it. Shouldn't need a gauge to tell you your engine is running like ****.
Old Jan 8, 2009 | 01:48 PM
smoke's Avatar
i will be able to hold 3 gauges
is oil temp more important than water temp because i have a coolant indicator stock?
my main concern about oil temp gauge is that i want to know when i can start driving in winter when i warm up my car. right now i just rely on the coolant but i know that isn't very accurate
Old Jan 8, 2009 | 04:07 PM
nj_08_gts's Avatar
It's not a Formula 1 car...use 0W-20 oil and let the car sit for a minute or two and then drive. Keep the revs low for the first few minutes on the road and you'll be fine
While there is a coolant temperature gauge already, it's more of an idiot light than anything. The only information it really provides you is when the coolant is at a nominal temperature or when the coolant is boiling over.
BbotVIII
Jan 31, 2015 06:27 AM
wiggam11
Oct 25, 2013 11:53 AM
LetsGo82nd
15
Jun 19, 2009 07:08 AM
Profoxcg
Oct 1, 2007 07:26 PM
silex
Feb 26, 2006 12:18 AM
