O2 sensor heater circuit malfunction
Old Jan 14, 2009 | 07:08 AM
cyrax5709's Avatar
Question O2 sensor heater circuit malfunction
So in the midst of diagnosing a problem I scanned the car to see what codes it was throwing. It came back with the obvious ones cause I have no cats but the one that threw me for a loop said o2 sensor heater circuit malfunction bank 1. Now I know that bank one means the one attached to the EM but does that mean the sensor is bad or its having a wiring issure?
Old Jan 20, 2009 | 12:43 PM
nestoledo's Avatar
The sensor is bad, change it
Old Jan 20, 2009 | 01:55 PM
cyrax5709's Avatar
Thanks. Would that make the idle inconsistent and the Air/Fuel ratio go crazy?
Old Jan 20, 2009 | 04:32 PM
xiaoni420's Avatar
Yup, I have the same issues unfortunately.
Old Jan 21, 2009 | 04:13 PM
cyrax5709's Avatar
Ok so onto my next question. Has anybody used a "universal" o2 sensor? They have those at the parts store in my area. basically its a o2 sensor with no connector. You would use the connector from the OE one im assuming. Any ideas/feedback?
Old Jan 21, 2009 | 04:21 PM
doctorjon's Avatar
I wouldn't see why it wouldn't work. Just splice the wires.
Old Jan 22, 2009 | 05:52 PM
cyrax5709's Avatar
So ive been looking for a diagram to figure out which wires are which when it comes to the o2 sensor and this is what Ive found. it was on the dsm forums so can someone tell me if this applies to the lancer as well.
Old Jan 23, 2009 | 06:53 PM
cyrax5709's Avatar
Ok so officially that diagram is very similar and the universal sensor works like a charm. turned off the CEL within 5 minutes. If anyone needs any help doing this just msg me
Old Mar 27, 2010 | 03:16 AM
checkin's Avatar
diagram
Did this diagram work for you,? the colors on my sensor are blue, red, white, & black on the original, am going to get the universal part & will need to know how to apply it to splicing in. Thanks Bob RMo8235376@aol.com
Old Apr 30, 2010 | 09:49 AM
Meaner's Avatar
I bought a Pre-cat Bosch Universal o2 sensor for my vehicle (according to auto parts dealer)... and it comes with "Black, Grey, White, White".
please advise.
Old May 1, 2010 | 10:48 AM
checkin's Avatar
reply to Bosch colors
I also bought a Bosch sensor for front from Pep Boys ($80, lowest price).
It shouldnt matter about the color codes, as the harness only connects in one way.
Added tip, check if the old one was torqued tight, when I went to change mine, it seemed very loose, as there is very little thread area, I installed the new one anyway, will always wonder if tightening would have solved the problem.
Old Jun 4, 2010 | 11:19 AM
jwick76's Avatar
Universals work fine, I use the universal for the second O2 sensor as I needed the extra length.
Just make sure you connect the wires according to the diagrams that come with the universal.
Old Jun 14, 2010 | 09:50 AM
eusgen's Avatar
Can someone post a direct link to a good EM o2 sensor. Im having trouble telling which sensors are for which part of the car. Im currently using rockauto to do my searching, here is their list of sensors.
http://www.rockauto.com/catalog/rafr...279855-2620311
Old Jun 15, 2010 | 12:28 PM
jwick76's Avatar
Anything's good, just watch out for the universals as they don't have the stock connector, you have to do splicing and wiring. Check autozone.com or advanceautoparts.com and they'll list the OEM sensor and you can make your choice from there...
Old Jun 15, 2010 | 12:40 PM
eusgen's Avatar
So if the o2 sensor says "front" i can still use it for any part of the car? im confused. I understand the universals need to be spliced, but i havnt looked at the o2 sensor under the car yet, just at the EM.
