Need help with ecu flash.
Old Jul 31, 2009 | 08:35 AM
*02Lancer*'s Avatar
I just purchased the taxtrix 2.0 cable and connecter set. I downloaded this c:\program files\openecu\ecuflash\ro...ubishi\lance r and i downloaded the top one. I then went on here and downloaded the definition files into the correct location. So i went out and connected the cable to the car and then to the labtop and connected. It did connect it under rom info says my year and trans my case ID and my internal ID whitch is 98720010. but when i go to click on anything else is just say's The current map description is invalid or incomplete. Please edit the map description to fix the problem and the map will be viewable again. and that's all i can do. is look at my Rom info. and the immobilizer What am i doing wrong? How do i go about loading my rom when not at my car.
