stroker kit for 4g94
Old Feb 15, 2010 | 07:38 PM
dspucches's Avatar
Is there any stroker kits for the 4g94, ive been lookin n no luck..
Old Feb 15, 2010 | 08:30 PM
senate6268's Avatar
No. The 4G94 is already a stroker motor. It is a stroked out and bored out variant in the 4G9x family of Mitsubishi engine. The cylinder walls are very, very thin with the 81.5mm bore in each cylinder and the stroke is long at 95.8mm. There is no room for (safe) improvement.
Old Feb 17, 2010 | 08:14 AM
mtype_06's Avatar
man, thats sumthing i actually thought about one day...couldnt ya sleeve the block if you really wanted to go through the trouble of stroking the engine further??
Old Feb 17, 2010 | 05:06 PM
senate6268's Avatar
If you haven't physically seen what the 4G94 block looks like, then it's hard to comprehend what I'm saying. The cylinder walls are thin as is. Very, very, very thin. Max overbore specs are minimal, as per the FSM. And even then that would be a piston replacement on a stock engine pushing stock horsepower. As Lancer owners begin to push their engines into the upper 300whp and into the 400whp numbers I'm mildly curious to see if anyone cracks a cylinder wall.
Old Feb 18, 2010 | 07:28 AM
mtype_06's Avatar
hmmm, i see what you're saying..sounds like was really trying cut back on costs rather than give us a new engine like they did the ralliarts at that time.
Old Feb 18, 2010 | 04:26 PM
senate6268's Avatar
Well the Lancer is really just a renamed, redesigned 6th generation Mirage. So it's understandable that Mitsubishi did what they did with the engine. The 4G69 is merely a redesigned 4G64 engine. It's got a shorter deck height and uses Evo spec'd rods with a slightly shorter piston to accommodate the 100mm crank. The 4G6x engines share similarities just like our 4G9x engines do.
Old Mar 20, 2010 | 10:57 AM
japordie's Avatar
yup and the ralliart motor is basically an eclipes motor.
Old Mar 21, 2010 | 09:12 AM
bluelancer20028's Avatar
should have taken the im and head from 4g93 and just put it on the 4g94 in the first place
EvilEvolution8
34
Apr 12, 2016 02:36 AM
j.p.
Feb 19, 2014 08:53 AM
Tonba
58
Jan 17, 2014 02:57 PM
dspucches
Lancer Tranny/Drivetrain Tech
Oct 29, 2011 12:36 PM
TitanMotorsport
Evo 'For Sale' Engine Internals and Drivetrain
Sep 30, 2009 02:45 PM
