ECUFlash help
Old Oct 26, 2010 | 02:16 PM
MurphDurph's Avatar
ECUFlash help
Ok so ive read the numerous threads that senate and others have posted bout flashing the evo rom on the lancer ecu. im running into the issue of adding the periphery into my xml to disable the immobilizer
https://www.evolutionm.net/forums/la...wap-works.html
i copied the added tables and pasted it to the xml as instructed...when i open ecuflash, i dont see the "periphery bits" under misc. or anywhere. i do however see the "immobilizer" option and the hex is at "0", but no other options. did i miss something somewhere? the rom im using is 94170715
Old Oct 28, 2010 | 05:50 AM
Mitsu.kid.02's Avatar
Just do this, its much easyer:
http://www.projecttuning.com/lancerRoms/ ... Unzip the files and put the 81870017 file in the rommetadata folder and then open the ROM (LancerAutoBigMaps) in ECUFlash. Dont forget to put the "lancerreadtemplets" in the directory too!
Old Oct 28, 2010 | 06:21 AM
link62's Avatar
mitsu thats rom is only for autos he is 5 speed so he can flash a normal evo rom to his ecu but for us autos we needed a custom one made
Old Oct 28, 2010 | 06:30 AM
Ohh wopps! i thought he was auto for a min, thanks for the correction link
Old Oct 28, 2010 | 07:43 AM
HornstarBU's Avatar
get the 9653 tephra rom and use it, or get the 9417 but that link is broken. both have those immobilizer and obdII and all that periphery bits already there.
Old Oct 28, 2010 | 04:51 PM
MurphDurph's Avatar
got a specific link to direct me? the 9653 i found didnt have the periphery bits...
Old Oct 28, 2010 | 05:42 PM
JRR's Avatar
JRR
when i did my evo ecu swap i just went to aktivematrix.com or something like that and just downloaded a stock evo rom and started with that one and added all the data to it.
josh
Old Oct 28, 2010 | 05:59 PM
03lances's Avatar
Its sounds to me like you dont have the right xml file to show you all the tables. If I am not mistaken that rom is the Tephra version correct? I had this issue as well, I can email you my xml file if you like to see if that fixes your issue
Old Oct 28, 2010 | 06:04 PM
MurphDurph's Avatar
yea its the Tephra version
Old Oct 28, 2010 | 06:42 PM
03lances's Avatar
Email sent man hopefully this will help
Old Oct 28, 2010 | 07:08 PM
MurphDurph's Avatar
thanks...i got the file and replaced the other, but i still dont see any of the peripheries or the MUT tables
im running ecuflash v 1.29 and have 1.3U cable
02 OZ MT
tephra rom 94170715
Old Oct 28, 2010 | 07:09 PM
HornstarBU's Avatar
each tephra should have the accompanying xml file, and you should ALWAYS get a new xml if you download or re-download the rom, cause they change the xml out sometimes, or re-structure it....and get rid of all your old ones, just the newest one is all you want to load..
Oh, um...some of the older versions won't work with certain things, like blobbits and all that crap. I don't know which things they are, but maybe the old version is the problem?
Old Oct 28, 2010 | 07:23 PM
MurphDurph's Avatar
i first tried it with the newest version of ecuflash and didnt see anything...then i uninstalled ecuflash and re-installed the 1.29 cause i thought maybe it was cause im using the 1.3U cable...i can see the immobilzer tab under the misc and when i open it, the hex reads "0000"
Old Oct 28, 2010 | 07:42 PM
03lances's Avatar
02 OZ MT
tephra rom 94170715
Wierd I am using the 1.3m and ecuflash 1.42
Old Oct 29, 2010 | 02:49 PM
Lancerboi808's Avatar
i had issue also but heres what i did see if its helps
try right click the ecuflash
go to properties
click on compatibility
and try chaninging the program mode
in something like windows 98 or what windows you have
