2 byte load, rpm, and airflow?
Old Nov 14, 2010 | 09:46 AM
ClixT's Avatar
has anyone tried modifying their stock rom to accommodate these values?
https://www.evolutionm.net/forums/ec...te-thread.html
https://www.evolutionm.net/forums/ec...l-dummies.html
https://www.evolutionm.net/forums/ec...s-like-me.html
EDIT: added some links
Old Nov 14, 2010 | 11:44 AM
HornstarBU's Avatar
Originally Posted by ClixT
I thought about trying to add stuff like that, but then decided that I wouldn't need 2byte load since I was only hitting 100 or so and most people look down upon lean spool and just recommend turning it off.
Are you running the stock rom btw? and do you have trouble going lean in the upper rpm range? I thought everyone was trying to use the evo roms, but I guess if you're using the base rom, then it would make sense to add stuff like that, if you hit 160+ load values.
Actually, most people agree that 2byte to 1byte load conversion is the "cool" way to do it these days, and that 2byte load is soooo last year.
Old Nov 14, 2010 | 12:10 PM
senate6268's Avatar
Only way to run these would be with an Evo-based ROM on the Lancer ECU. Anyone running a non-Lancer ROM has no reason not to be using 2-byte values for logging.
Old Nov 14, 2010 | 01:05 PM
ClixT's Avatar
oh ok. im not running an evo rom.
so whats the most accurate load then for a stock rom?
Old Nov 14, 2010 | 06:18 PM
HornstarBU's Avatar
Well, ecuload is plenty accurate under 160. You are using the stock rom though, with no problems getting the car to run rich enough? You're not turbo, right?
Old Nov 14, 2010 | 06:49 PM
Mitsu.kid.02's Avatar
+1 are you N/A or have you begun your build?
Old Nov 14, 2010 | 10:06 PM
ClixT's Avatar
im n/a.
ive been using load calculated for a long time now, and i just thought of 2 byte load now lol
tephra
Dec 26, 2023 01:11 PM
nuk1ear
Nov 27, 2016 05:13 PM
tephra
Jul 25, 2016 02:21 PM
Cbr1000love
Jan 31, 2016 05:01 PM
chaotichoax
Sep 7, 2015 07:41 PM
