Looking for a 04-06 MT rom
Old Oct 10, 2011 | 11:31 AM
jakermeister's Avatar
Heres the rom. I'll wait to flash the automatic rom till you check my rom out. Let me try flashing my rom first to make sure i can go back. Also, I downloaded the 05-07 big map rom for the automatic but theres no definition. Should I make one with a existing definition??
File Type: hex
Old Oct 10, 2011 | 11:34 AM
RoadSpike's Avatar
The definition is in a separate download just look for the zip file in the same post.
Old Oct 10, 2011 | 11:37 AM
Cool. Good news. My rom flashed back so I'll download the definition and give the automatic rom a try in a bit.
Old Oct 10, 2011 | 11:38 AM
RoadSpike's Avatar
Checking your rom and the data stops at 256kb but that doesn't mean its not a 512kb capable ecu could be they just slapped the 256kb in a 512kb package ecu's are the same anyways.
Old Oct 10, 2011 | 11:43 AM
found the definition LOL funny i didn't notice it when I downloaded the 05-07 rom. I'm gunna try the automatic rom right now.
Old Oct 10, 2011 | 12:04 PM
I blew my engine!! JK Automatic flash worked so I went for a short drive around the block. Does the ecu relearn when flashing a new rom? It felt like it was relearning so I took it easy on it. I didn't see any knock so thats a good thing. With 05-07 rom I flashed will that be the rom I use for boosting?? The maps were so big! Car felt a little boggy and would chug just a hair. Nothing out of the ordinary tho. Just felt like it was relearning.
Old Oct 10, 2011 | 12:11 PM
RoadSpike's Avatar
Nice no surprise the car felt a bit slower that map was made to be safe not race ready. Its a starter map so people moving to turbo don't blow up.
Old Oct 10, 2011 | 12:15 PM
So thats my boost rom right??? Those maps were so huge!! I was a little overwhelmed with all the info in it LOL
Old Oct 10, 2011 | 12:27 PM
RoadSpike's Avatar
Yep should be a super safe starting point for boosting.
You could try running an evo 9 rom but i'm thinking that may be a bad idea with the MIVEC missing that would be pretty nuts. Or does your car have some kind of MIVEC system in it?
Old Oct 10, 2011 | 12:33 PM
LOL no mivec. I've been reading the evo section and I hear the mivec stuff still has fuzzy areas as well. I really appreciate your help RoadSpike!! I don't know what we would do without you.
Old Oct 10, 2011 | 08:13 PM
RS I was looking at the maps and the shift maps and all the other stuff is just there right? Meaning its useless? Basically all of the automatic transmission maps are in a baby blue color.
Old Oct 10, 2011 | 09:48 PM
RoadSpike's Avatar
Don't worry about the auto stuff you car has no hookups for it anyways.
If anything I was more worried about you throwing a CEL for the auto being gone but it doesn't seem that way for some reason
Old Oct 11, 2011 | 07:11 AM
There was a check engine light on but I didn't bother to see what it was. When I was logging there was a warning for "high coolant temp" on the evoscan but it went away after a while. Wasn't sure why it was on the car wasn't even warmed up till I test drove it. For the most part the car felt "ok". I'll need to pull my piggy back out soon. I'll try to flash it after work and see if I can pull any DTC's.
Old Oct 11, 2011 | 04:59 PM
Well you were right. I had a check engine light on for "P1751". Which is for the transmission LOL Should I just clear it?
Old Oct 12, 2011 | 01:29 AM
RoadSpike's Avatar
may be a simple way to disable the transmission code but for now you'll probably just have to live with it.
