Ingen CAI 2.0 to work in the 2.4
Old Oct 22, 2011 | 06:15 PM
asidrave's Avatar
I bought the wrong CAI for my 09 GTS. What are the differences between the 2? I have not yet installed it
Old Oct 25, 2011 | 12:00 PM
lancer0220's Avatar
i know ive posted about this somewhere on here.
anyway dont use it, the 4b11 and 4b12 injen intakes vary significantly, although they look they same they are not.
Return or sell the 2.0 (4b11) intake and get the proper intake, also to avoid any issues with water consider the Takeda sri, it has yielded great gains and stacks up pretty well if not better than the injen cai.
Old Oct 25, 2011 | 02:56 PM
evo_soul's Avatar
1+
Lancer0220 hit it on the head
The only thing I wanted to add was to explain why. INJEN intakes employs a trick to allow un-metered air to by pass the Mass Air Flow Sensor. As a result, your car's O2 sensor will detect this and send instructions to the ecu to make minor corrections to the fuel trim. The end result is a more rich mixture. This keeps temperatures down and safe while maintaining good HP / TQ gains.
The problem you face is using the wrong intake will upset both the correct amount of air entering the engine and how much unmetered air is by passing the MAF. While it will not kill your car. You will likely trigger lean codes, and for the long run, that is bad.
Old Oct 25, 2011 | 03:53 PM
asidrave's Avatar
Thanks for the replies. I put it up for sale yesterday in the classifieds. Hopefully with that cash and some extra ill get the takeda sri
Papogremlin
Lancer Engine Tech
Sep 12, 2014 10:44 AM
m.s.p
Lancer Engine Management / Tuning Forums
May 8, 2012 02:25 PM
phuknrht
Toronto Lancer Club
Jul 27, 2009 07:09 PM
grubiaco
Apr 17, 2006 12:09 PM
tama_mog
28
Apr 23, 2005 03:37 PM
