4G94 N/A Build Vendor's & Part #'s (STICKY)
Hope their can be a sticky on all 4G94 M/T or A/T N/A Build for our 2.0 Engines.
RRM:
P# Throw out Bearing 4G94
P# Stage 1 Camshaft 4G94
P# Headers (Exhaust Manifold) 4G94
P# High Performance Complete Head Gasket Kit
P# Bored Throttle Body 4G94
P# Forged Pistons 4G94
P# Lightweight Pulley 4G94
P# Bored Intake Manifold 4G94
P# Ported & Polished Complete Head Stage 2 4G94
AEM:
P# 21-434 Cold Air Intake
K & N:
P# 33-2105 Stock Replacement Air Filter
P# HP-1010 Oil Filter
P# 69-6540 Short Ram Intake
Injen Technology:
P# RD1830 Cold Air Intake (M/T ONLY!)
P# D-476-4 Replacement Air Intake Filter (M/T ONLY!)
P# IS1830P Short Ram Intake
P# X-1018-BR Replacement Air Intake Filter (A/T ONLY!)
Unorthodox Racing:
P# 070941304 Clutch Kit (M/T ONLY!)
P# 070941314 Clutch Kit (M/T ONLY!)
P# 070921310 Clutch Kit (M/T ONLY!)
P# 070931314 Clutch Kit (M/T ONLY!)
Competition Clutch:
P# 50512400 Stage 1 Clutch Kit (M/T ONLY!)
P# 5051-2100 Stage 2 Clutch Kit (M/T ONLY!)
P# 5051-1680 Iron Man Clutch Kit (M/T ONLY!)
P# 5051-2300 Stage 3 Clutch Kit (M/T ONLY!)
P# 5051-1680 Stage 4 Strip/Street Series Clutch Kit (M/T ONLY!)
P# 5051-0620 Stage 4 Strip Clutch Kit (M/T ONLY!)
P# 5051-1420 Stage 5 Strip Series Clutch Kit (M/T ONLY!)
P# 5051-0420 Stage 5 Clutch Kit (M/T ONLY!)
Clutch Masters:
P# 05-054S-HD00 Stage 1 Performance Clutch Kit (O.Z Rally ONLY!)
P# 05-054S-HDKV Stage 2 Performance Clutch Kit (O.Z Rally ONLY!)
P# 05-054S-HDTZ Stage 3 Performance Clutch Kit (O.Z Rally ONLY!)
P# 05-054S-HDCB4 Stage 4 Performance Clutch Kit (O.Z Rally ONLY!)
P# 05-054S-HDCB6 Stage 4 Performance Clutch Kit (O.Z Rally ONLY!)
P# FW-632-AL Flywheel (O.Z Rally ONLY!)
Weapon-R:
P# 950-129-102 Cold Air Intake Box (M/T ONLY!)
P# 826-111-101 Universal Reservoir 24oz Coolant Aluminum Overflow Tank
P# 826-134-101 Universal Reservoir Bottom Inlet Tank
P# 826-211-101 Universal Reservoir 180oz Short Coolant Tank
P# 959-111-104 Universal Torque Damper
P# 826-113-101 Universal 24oz Oil Catch Tank
P# 826-213-101 Universal 180oz Oil Catch Tank
P# 826-313-101 Universal Pro Tank Oil Catch Tank
NGK:
P# 5464 Iridium XI Spark Plugs
DC Sports:
P# CAI6001 Cold Air Intake System (M/T ONLY!)
Gates Racing:
P# K040305 Alternator V-Ribbed Belt
P# K040305RB Altenator High Perofrmance Blue V-Ribbed Belt
P# K050516 AC/PS V-Ribbed Belt
P# K050516RB AC/PS High Perofrmance Blue V-Ribbed Belt
P# 36238 Tensioner Pulley Belt Drive Pulley
P# TCK201A Timing Component Kit
P# TCKWP201A Timing Belt Component Kit W/Water Pump
P# T201 Cam Timing Belt
P# T201RB Cam High Performance Timing Belt Blue
P# T41212 Cam Tensioner Assembly Timing Belt Tensioner
P# KS13907 Cam Seal W/O Turbo Timing Component Seal
P# KS14671 Crankshaft Seal W/O Turbo Timing Component Seal
P# 22721 Upper Coolant Hose
P# 22720 Lower Molded Coolant Hose
P# HK9RB Radiator Hose Kit High Performance Molded Coolant Blue
P# 31428 Cooling System Adapter Cooling System Tester Adapter
P# 33987 O.E Thermostat 180 Degrees
P# 33661 Thermostat Seal
P# 42280 Water Pump Standard
P# 348562 Pump Seal Kit Power Steering Repair Kit
Fidanza:
P# 961436 Cam Gear RED
P# 961434 Cam Gear BILLET
P# 961439 Cam Gear BLUE
P# 229501 Flywheel 9.5 lbs.
P# 861000 Short Shifter (M/T ONLY!)
Spyder Auto:
TS-HE-ML02-C Headers (Exhaust Manifold)
Kamikaze:
MLH2004 Headers (Exhaust Manifold)
Magnecor Competition:
P# 47182 7mm Spark Plug Wires
P# 45182 8.5mm Spark Plug Wires
P# 40182 8mm Spark Plug Wires
Edelbrock:
P# 38123 Universal 70mm Throttel Spacer
Carbing:
P# CA 220 001 0 T Universal 0.6L Fitting Type Reservoir Tank
P# CA 220 002 0 T Universal 0.6L Hose Type Reservoir Tank
P# CA 206 010 1 T Universal 10mm Hose Fitting Oil Catch Tank
P# CA 206 015 1 T Universal 15mm Hose Fitting Oil Catch Tank
NRG Innovations:
P# EDA-500CF Universal Large Torque Damper W/O Bracket Gun Metal
P# EDA-501CF Universal Small Torque Damper W/O Bracket Gun Metal
P# OCC-100C Universal Oil Catch Tank Chrome
P# OCC-100BK Universal Oil Catch Tank Black
P# OCC-100WH Universal Oil Catch Tank White
Greddy:
P# 12004901 Universal Oil Relocation Kit
Perrin Performance:
P# ASM-ENG-6 00BK Universal Oil Catch Tank Black
P# ASM-ENG-6 00BL Universal Oil Catch Tank Blue
P# ASM-ENG-6 00RD Universal Oil Catch Tank Red
more coming soon..
RRM:
AEM:
K & N:
Injen Technology:
Unorthodox Racing:
Competition Clutch:
Clutch Masters:
Weapon-R:
NGK:
DC Sports:
Gates Racing:
Fidanza:
Spyder Auto:
Kamikaze:
Edelbrock:
Carbing:
NRG Innovations:
Greddy:
Perrin Performance:
more coming soon..
doncarbone
Oct 17, 2024 05:44 PM
FS[Northeast]: 2007 Audi A4 DTM 6MT Quattro Stage 3 GT3071R
kristokes
Jun 28, 2015 02:57 PM
JDM_CEDIA
Lancer Engine Tech
Feb 12, 2014 12:26 PM
Unified-Forums
161
Oct 22, 2011 10:44 AM
